Old 08-09-2011, 03:09 AM
Bretd Bretd is offline
Boat: Mastercraft X-9, 03 predator
Ballast won't work
When I turn the pump on it runs but won't prime it sounds like it is just pulling air is the pump out?
Old 08-09-2011, 10:59 AM
jvbaca's Avatar
jvbaca jvbaca is offline
Boat: Mastercraft X-45, 2005, LQ9 closed loop cooling
Probably your impeller in the ballast pump.
Old 08-09-2011, 12:42 PM
i changed out the impeller and it still wont prime how do you know when the pump is out will it just not turn on
Old 08-09-2011, 07:37 PM
jvbaca's Avatar
Check the hose for a leak if you can follow it at all. Make sure the connection to the pump is tight.
I would call the Mfg. (jabsco?) and talk to their tech or engineering dept. They helped me out when mine weren't working (turned out to be an impeller issue.
Old 08-11-2011, 06:25 PM
bnixon's Avatar
bnixon bnixon is offline
Boat: Mastercraft X10 2001 Vortec 350
What year is your boat? My x10 has the aerator style pumps and there were some cable actuated valves that the actuators were broken and they were closed even when the knob showed them open. Replaced them and mine then worked fine. If you have the knobs in the rear locker that might be your problem.
