This is what my ladder looks like both top and bottom. I hope this helps.
#12
The ladder is held on by stainless bolts with nuts on the bottom. The fiberglass is pretty thick there, maybe 2". You can get your hand underneath to hold the nut while you or a helper turns the phillips head of the bolt.
It appears that an anchor can still be stowed even with the ladder installed, although I've never tried it. It would have to be the proper size anchor. Hope all of this helps. Oh yeah, if I'm ever in your neck of the woods how about a pull? ![]()
I was njskier on here. |
#13
Thanks guys! Drilled the first two holes and installed the first two bolts. Total thickness is approx 1.25" under the ladder mount area. Clearly reinforced specifically for the ladder. You guys must have a larger cutout as I really can't get my hand in there. So, I'm super gluing the washers and nuts together so I can make it work:
![]() For the bolts closer to the inside, where I have even less room (and not enough room for the 1.5" fender washers), I have to use smaller washers than the large fender washer combo above. Oh yes, I am super gluing the assembly to my finger tip to get it up to the bolt (its that tight in there): ![]() 1/6th success! ![]() Thanks again. Good thing my boat already came with the ladder warning label.
Never Mind The Bollocks, Here's The X-Star Last edited by deminimis; 08-10-2011 at 12:30 PM. |
#14
I've got the four aft bolts and nuts installed. It is absolutely impossible to do it like that for the remaining eight bolts. No possible way to get a hand under there with my configuration. For the remaining eight bolts, I may pull the bolts up through the bottom (using line and a spring threaded onto the bolt) and have the nyloc nuts visible. Option two is to come up with some SS weld nuts and fish then up and into the drilled holes (requires a larger hole). McMaster-Carr has. Might be the most sano solution. Like this:
Never Mind The Bollocks, Here's The X-Star Last edited by deminimis; 08-10-2011 at 12:31 PM. |
#15
What about putting your superglued nut & washer in a box end wrench? Or is the space too tight for that as well?
2008 X45 LY6 All the way! Airborne! |
#16
Thanks, but that wouldn't work either. I can only get my hand under there to mid-palm. Hard to discern from the pic, but its tight.
![]() Oh well. I still think it's funny that my boat came with the ladder warning sticker and no ladder, yet Dave's and VWS' boat came with ladders, but no ladder warning stickers.
Never Mind The Bollocks, Here's The X-Star |
#17
......Hellya!
#18
This will be the last update on this project unless something changes. Went ahead and ordered the above SS weld nuts as well as fender washers that will fit the barrel to spread the load. Also splurged for phillips head pan screws (the higher quality stainless).
So I can finish the project for now, I'll go ahead and pull bolts up from the bottom (with the flat and fender washer combo) and have exposed nylock nuts. That will get me through the weekend in the unlikely event the wind freak'n dies down enough to put the boat in the water. Once the parts arrive, I'll remove everything and start over. I'll enlarge the holes I drilled in the deck to accommodate the weld washers' 5/16" x 7/16" barrel (1/4-20 thread). I'll pull the weld nut and fender washer combo up through the bottom. I will have epoxied the all mating surfaces so once its done, its done forever and it ain't go'n-a-nowhere. In a nutshell, I'm creating load-dispersing stainless inserts. Should the ladder ever need replacing, one just needs to remove the 12 screws with a phillips screw driver. Over-engineering this a bit, but whatever.
Never Mind The Bollocks, Here's The X-Star Last edited by deminimis; 08-10-2011 at 12:37 PM. |
#19
1998 ProStar 190 30th Anniversary, Corvette LT-1, STARS AND STRIPES BABY (with a really bad bimini)!!!!!!** * Footin' anyone?RON PAUL FOR PRESIDENT "May future generations look back on our work and say that these were men and women who, in a momnet of great crisis, stood up to their politicians, the opinion-makers, and the establishment, and saved their country." - Ron Paul |
#20
Yup, it was all composite materials (several different kinds).
