Old 08-05-2011, 01:18 PM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
Ballast again
After reading through numerous ballast threads, I haven't found a solution for my issue.
I've already replace the pump and impellor. My KGB (center) bag will fill but not empty. I can blow through all lines, so nothing is clogged. If I disconnect the fill/drain line from the KGB at the pump, water will drain on it's own, but if I try to pump it out, nothing.
2002 X Star
Sold - 76 S&S
Old 08-05-2011, 01:37 PM
G-Star's Avatar
G-Star G-Star is offline
Boat: 2002 X-Star, LTR
Is your ballast totally stock, or have you added/changed anything?
2002 X-Star w/ LTR
Old 08-05-2011, 02:42 PM
76S&S's Avatar
Boat: 2002 X Star
Not stock but have been running it this way for a year or more.
The overflow from the KGB goes into a second bag in the bow. The additional bag then overflows out of the stock overflow thru hulls. When draining, the bow bag, "gravity" feeds the KGB, to the pump, then out the drain. Currently both, KGB and bow bag are full. I can blow through the KGB line at the pump and air comes out the overflow, so there are no obstructions in the plumbing.
2002 X Star
Sold - 76 S&S
Old 08-05-2011, 02:46 PM
kskonn kskonn is offline
Boat: 2003 X-30
Are you able to get a vacum on it so that the pump can pull water from the bag?
Old 08-05-2011, 02:47 PM
G-Star's Avatar
Does the bow bag (IBS?) empty, but not the KGB? or does neither empty?
2002 X-Star w/ LTR
vision's Avatar
vision vision is offline
Boat: 2008 X Star, 2005 X2
Sorry I do not know all that you have already done so I maybe suggesting something you have already tried, but:
1. Have you replaced the impeller in the KGB pump. Pumping one way but not the other can be a sign of a bad impeller (not flipping correctly). If the impeller looks ok, try greasing the interior housing.
2. By all lines, do you also mean the over flow/vent line as well? If you pour fluid into the vent for the KGB does it easy make it to the sac?
3. Is there a lot of air in your KGB preventing the pump from priming (or is the line from the pump to the sac connected to the incorrect fitting, i.e to the top and not the bottom).
4. Lastly, if you switch pumps temporarily does it work (ruling out pump versus lines).
2008 X star, 2005 X2
Old 08-05-2011, 02:48 PM
Boat: 2003 X-30
My money is on priming, I have seen this before when extra bags are added.
Old 08-05-2011, 02:55 PM
76S&S's Avatar
Boat: 2002 X Star
Don't have vacum pump.
2002 X Star
Sold - 76 S&S
Old 08-05-2011, 02:58 PM
76S&S's Avatar
Boat: 2002 X Star
1. Have you replaced the impeller in the KGB pump. Pumping one way but not the other can be a sign of a bad impeller (not flipping correctly). If the impeller looks ok, try greasing the interior housing. Replaced pump and impeller
2. By all lines, do you also mean the over flow/vent line as well? If you pour fluid into the vent for the KGB does it easy make it to the sac? yes
3. Is there a lot of air in your KGB preventing the pump from priming (or is the line from the pump to the sac connected to the incorrect fitting, i.e to the top and not the bottom). KGB is full as a tick of water
4. Lastly, if you switch pumps temporarily does it work (ruling out pump versus lines).I've tried two different pumps and impellers
This is not a new install, I've been running this way for quite a while, but all of the sudden it won't empty.
2002 X Star
Sold - 76 S&S
Old 08-05-2011, 03:00 PM
76S&S's Avatar
Boat: 2002 X Star
But...........if I simply disconnect the hose from the KGB at the pump, water starts flowing.....that is why I can't figure out why it won't pump.
2002 X Star
Sold - 76 S&S
