Old 08-03-2011, 05:20 PM
rhob88
Posts: n/a
steering for a 94 m/c 205
my 94 205 steering has a dead spot in it when the the rudder is neutral, really notice it turning the rudder to the left ,greased the fittings already .anyone have any ideas , thanks
Old 08-03-2011, 05:27 PM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
Did you grease the rudder fitting? there are three fittings at the back, that deal with steering. Two on the cable it self, and one on the rudder.
If you have done all three. and you still have a hard spot. try taking the cable loose from the rudder. and see if its still there. also while it is unhooked turn the rudder with your hand to see if its in the rudder.
worst case: you need to remove rudder and clean out packing. and re grease,
and install new steering cable.
do a forum search there are a lot of threads on steering
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 08-03-2011, 05:31 PM
rhob88
Posts: n/a
only fitting that was not greased was the solo rudder fitting under the fuel tank,its more like a dead spot thats about 1/8 rotation of the steering wheel
