Old 07-26-2011, 10:03 PM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is online now
Boat: 1987 PROSTAR 190
87 prostar skipping
Okay we arrived at the lake on Sunday and are staying all week. After I launched the boat and got underway it loses power as I begin to accelerate. It starts fine, idles fine, and revs fine in neutral. It kind of stutters when you take off until around 2200 rpms. It will also run hard as long as you gun it and the secondaries open. At around 3000 you can hear and feel a skip. Ran fine last weekend. Since then I have changed plugs, filled with gas, replaced the thermostat, and the kill switch. It has also stayed at a fast idle a couple of times 1100 today even though it was warm. Any ideas for a quick fix at the lake? I've run it like this for 2.5 days it is aggravating but has not let me down yet.
Old 07-26-2011, 11:31 PM
I see you changed spark plugs, Probably got your wires crossed up. Since it didn't do this before you changed them out.
James
Old 07-26-2011, 11:39 PM
I assume you have the ford 351, if so then, counterclockwise 1 3 7 2 6 5 4 8 is the firing order.
James
Old 07-27-2011, 01:13 AM
Yeah 351 hope its something like that. If not I'm wondering if I goofed one of the wires up when I changed the plugs a coupled were pretty hard to remove.
Old 07-27-2011, 01:21 AM
Btw the cylinders are numbered starboard side is 1 2 3 4 and port is 5 6 7 8.
James
Old 07-27-2011, 03:57 AM
mastercraft-4-life mastercraft-4-life is offline
Boat: 1985 mastercraft stars and stripes, 351 ford
I have a 1985 s&s Ford 351w I am having the same problem I am down to changing the disturber and the full pump I have change everything else. So look in to those.
Old 07-27-2011, 07:12 AM
oldairboater's Avatar
oldairboater oldairboater is offline
Boat: Mastercraft, Prostar, 1992, 351 Ford
Most problems are electrical in my experience. Why would you change the distributor? Something wrong with it? I have seen distributors wear out and get so corroded they weren't worth the hassle. Most times mechanical fuel pumps work or they don't work and leak. If I suspected anything fuel related it would be old fuel/ water in fuel or fuel filter.
Old 07-27-2011, 07:15 AM
Boat ran fine? Why did you change all those parts out? Have you looked to see if your carburetor is returning to the idle screw and if the choke is open?
Old 07-27-2011, 08:58 AM
I changed the thermostat because it was reading 20-40* hotter than the actual water temp, kill switch line was screwed up so I replaced the whole switch, I usually change the plugs every year regardless of hours and had not this year, and it won't run at all without gas. To rephrase the engine rand fine with no skipping or hesitation. Headed to the dock now to have a look at the plugs. Thanks for the replies ill give an update if I figure the problem out.
Old 07-27-2011, 01:01 PM
I hate these kinds of problems. I would still look at fuel filters and the fuel itself. I am paranoid about gas here. Our humidity and ethanol they add makes fuel a real problem sometimes. I will not buy fuel at a lot of the places on the water--good people but if they don't move enough fuel it goes bad. Which carb you running? I would still look at the carb. You change plugs annually and doing all you have done your not afraid of your tools. If it was me I would check my plugs again and firing order. Look at my rotor and distributor cap. Then me and my carb would be spending some quality time together before I took it off of the boat. I would check my linkage and choke. Accelerator pump and then I would be pulling the top off to look at floats and needle valves. Just a warning---I figure you know this but I have to say it anyway. Don't drop anything into your intake manifold pulling all these screws loose. Then depending on what I find I would either rebuild, replace, or call a friend.
