Star Gazer Perfect Pass - how easy
So I picked up the Stargazer Perfect Pass and have it all unpacked and it seems shockingly easy to install
Master module gps/engine connector GPS module display connector and dash display? I've been searching for some instructions on what to do behind my 2006 MC X1 Dash, but it seems it's all plug and play? Am I missing something here, I'm a pretty confident around the boat, but this seems like there should be something else to this?? or is it really this easy to isntall in my DBW MC.
_____________________ current: 2006 Mastercraft X-1 past: 1986 Mastercraft Skier 19 1978 Ski Tique 1987 Mastercraft ProStar |
Its easy plug and play.
1997 Prostar 190, TBI 350, 1:1, OJ XMP 13 x 11.5, Stargazer, Hot Shower, Heated Drivers Seat, Reuben/Mountain Rock/Nite Navy |
Its pretty simple, upgraded to StarGazer PP myself this spring. Plug and play...
Did you have PP before? I would like to know how different it is to install and what you need to swap out...
Thanks guys, I know there are a ton of threads on here for this, so I do appreciate it! It looks like that engine connector is beind the kick panel? That's about the only gotcha in the whole install isn't it? Also heard about weak grounding wires with the 06's any thought on that, and needing: this
"The one thing not show or discussed anywhere was the ground plug that connects on the back of your motor- the ALDL I ended up picking this plug up from my dealer for $15. They did caution me that the 06's are notorious for having grounding issues, so good luck!""
The hardest thing, by far, is running the cables to the servo (or ECM if you are TBW). Outside of that it is really easy.
94 Prostar 190, LT-1, Powerslot |
Well not as easy as I thought.... Install went fine / dash is up but motor is not being taken over by the pp / everything I read says grounding or this special plug that is needed?? Thoughts??
You have to take the boat to the dealer so they can reflash your ECM.
www.nwboatsports.com |
