PS 214 dimensions for garage
We are adding a new garage to our fixer house and it would be nice if I ever go to a 214, it would fit in the garage. Right now, we have 9 feet wide, 8 feet tall and a depth of about 23 feet.
Can I get a 214 in there?
- Jeff 1994 205, LT1 |
23' deep would also be a little close for comfort. Especially if you leave the swim platform on. The tongue will swing away but I'm a fan of more space. In my book if you're going through the hassle of an addition for the boat you're better off to error on the heavy side versus the light side. You can always find a way to use that extra space. But if it's too small, you'll always have the regret. |
The depth right now is 28' but with cabinets and some walking room, I said 23'..... How close to the sides do the fenders get on each side? Say 6"? Thanks for the help.
I believe all the trailers are just shy of 96" fender to fender. The wider the boat, the higher it sits up over the fenders and the wider the guide poles are.
My old 190 would just barely go thru an 8'wide door, rubbed the door seals. My X2 trailer is the same width, but the guide poles are bent out and well over 8' out to out.
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
Tampa Bay's Exclusive MasterCraft Dealer www.BAYAREAWATERSPORTS.com (813) 996-BAWS (2297) |
Jeff my bubble was burst a few days ago when I read that an X-25 wouldn't make it through an 8' high garage door with the tower down. It would be nice to have some height specs for all the boats on trailer with towers down. Did you guys leave any fish up in Alaska last week?
2006 Maristar 200 SS |
#7
I have an x-14 and keep it in my basement garage. Had a '93 PS205 when I built the house, and I went 9' wide with the door. I didn't think too much about height because at the time towers were just starting to show up on boats, so it is normal 8' high. The x-14 does fit with the tower down, and I take it in and out every weekend. It is not the easiest thing to do, but for me it is worth doing to keep it inside. Once you add the trim on the doors, the guide poles just barely fit, but yes, a 214 with tower down will go in an 8' high x 9' wide door.
My garage is 27' deep, and that allows plent of space to get around it on all sides, once it is in. I would have to measure, but I think 23' is doable with trailer folded, and pladform dropped. |
#8
My new garage space for my X14 coincidentally has 9' wide, 7' high door and ~24' depth. There is no more than a half inch space on each side of the trailer guide poles. Height makes it but I need to remove half of the slalom rack. Board rack fits. There is an 18" deep shelf I have just over 22' 6" depth and it fits with maybe 1" to spare with tongue folded. Kind of a drag coming from a garage with a 16x10 door and 28' depth where I could zip it in with tower up and boards and ski's on racks.
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#9
good point on removing 1/2 the slalom rack, I have to do that as well. Also, I have to unzip the oustide section of the bimini top, and lean it back until it clears the door.
2008 X-14 MCX 1993 Prostar 205 1982 S&S |
#10
Another good point, I needed to remove my bimini. I forget why....I think to fold the racks closer??? It was February and there was 3' of snow lining the driveway, so I was just glad I got it in at all. Wasn't paying close attention to little nuances.
