i could use a pic from an x1/205v etc
Can somebody post a quick pic of either rear ballast pump location. I know they're on the transon behind that carpeted wall, but when i looked at my 205v, i saw a couple spots where they could be mounted, so a pic of a stock mount would be very helpful. Also, any idea how long the mounting screw is? I'd prefer not to poke out the other side. Thanks!
I won't call myself a hero...I'll let history decide. |
I've got some I can post up tomorrow morning.
I'll subscribe so I remember ![]()
2002 X-Star w/ LTR |
Thanks so much! I knew somwbody would come through.
1997 Prostar 205, LT1 powerslot I carry a gun because a cop is too heavy |
K... here we go. Port, starboard, and everything.
You can see the thick area extends below the thru-hull bolts for the transom rings. That's where the 4 ballast pump screws go. I can't remember what length the screws were though. I guess you could pull out the transom ring and measure thickness?
Some detail shots of the pumps.
Perfect. Thanks.
G-star thanks for the pictures I too was needing some. Was there a plate or panel in front of the pumps that hide it from the storage area? or are the pumps seen just as they are?
I have a 1999 and I dont have a panel there. But hope to put my pumps there. How do they work being up so high from the water line?
"Let me not pray to be sheltered from dangers, but to be fearless when facing them." 1999 X-star, 330 LTR, Zero FLex tower. |
can you take a picture of your thru hull where they get water ?
is there a valve at the thru hull?
