Old 07-26-2005, 06:45 PM
wakebdr2002 wakebdr2002 is offline
Boat: 2001 X-star
Send a message via MSN to wakebdr2002 Send a message via Yahoo to wakebdr2002
Starting Problems
Hi everyone, I'm new to this board and thought I might be able to get some technical advice here. I have purchased an '01 X-star earlier this year and it is giving me problems starting after it has been sitting for a few days. It has the 330 HP EFI upgraded engine. If the boat hasnt been used for 2 or more days it will not want to start. I have to crank it for a long time (usually 15 secs at a time with a few mins for the starter to cool) doing this for a while (half hour or more) it will eventually start. Once it starts it will run perfectly all day and start right up everytime. While we were trying to fix the problem we pulled a spark plug and tested it and noticed that it is not getting spark, but it is getting fuel. When cranking it with the spark plug out, it had no spark, but after a few minutes of cranking we saw spark and the engine fired right up. We checked for loose wiring and couldnt find anything. I am thinking it might be a problem with the engine's computer but I have no idea how to check that. If anyone has seen this problem or has any ideas of what the problem is I would greatly appreciate the help.
Old 07-26-2005, 07:19 PM
JEREMY79's Avatar
JEREMY79 JEREMY79 is offline
Boat: 1979 stars and stripes
Wow dude that sucks. While I cannot help you, I can bump your post back to the top.
#1 supporter of wadka
Old 07-26-2005, 07:34 PM
bradamerry bradamerry is offline
Boat: 93' Barefoot 200
79, what you meant was add to your post count!!!
Swaha Lodge Lake Greeson Akansas..... www.swahacabins.com
Old 07-29-2005, 09:08 PM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
I would check the output of the crank position sensors located at the front of the engine. At cranking speed, they should have an output of .8 to 1.4 volts each. If they are not producing a strong enough signal, the ignition module may not be able to fire the coils. If the voltage is low, you might try loosening the bolts that attach the bracket to the engine and try to work the sensors a little closer to the trigger wheel.
Engine Nut
Engine Nut
Indmar Marine Engines
Power to the Sport
Old 07-29-2005, 10:25 PM
rodltg2 rodltg2 is offline
Boat: 2017 PS
Send a message via AIM to rodltg2
wow, i wish you lived by me. that advice way beyond me.
Old 07-30-2005, 12:00 AM
mcprostar197 mcprostar197 is offline
Boat: 2004 Prostar 197, 310 hp
Do you give it gas and try to rev the engine when you are starting it after a couple days? Not that you should have to do it with a decently new boat, but I used to have to do that with our 2002 Glastron when we had it and didnt use it for a couple days.
Old 07-30-2005, 10:42 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Perhaps a bit overly simplistic, but did you throw in a new plug when the one you tested didn't initially get a spark? From your post, I couldn't tell.
If it's getting fuel and air, then fire is the problem. How are the plugs and plug wires. How are the connections on the wires.
/it's not that I didn't read engine nut's post, I just didn't understand it.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 07-30-2005, 10:45 AM
6ballsisall's Avatar
Boat: None this week!
yeah brad, you getting worried he's gonna catch you??
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
Old 07-30-2005, 10:46 AM
JEREMY79's Avatar
Jeff you done passed me, there bud
No I really wanted the help the guy out. Bump his post up.
Old 07-30-2005, 10:47 AM
André's Avatar
André André is offline
Boat: Prostar 190 1994
I think the cranking sensors give the signal that the starter is turning the engine and that the ignition module should give fire then...ICBW!!!
Keep skiing!!!
