X25 shower retrofit
I'm looking to install a shower kit (perhaps the OEM one from heatercraft) on my x25SS. Since i have a freshwater washdown tank, i figured it shouldn't be too hard to do. I even have a shower switch on the transom which lights up whenever i turn it on.
I was trying to find pictures of where it usually is mounted in factory boats but cant seem to find much. any ideas on where i could possibly put it? |
It's mounted in the fiberglass on the side of the cutout for the port transom seat. You have to flip up the seat to see/access it. I can take a pic later if nobody else has one.
Hot water comes off the engine though for the shower. With closed cooling, the only hot water you have would be coming off the exhaust which isn't clean water I''m guessing.
Here's where I mounted the controls on my X2. Pump is in the engine bay and I tapped cold water off of the prop shaft seal water supply, hot water off the intake manifold, red hose in the picture. Pulling off the washdown tank, you already effectively have a cold shower, pump and all, right? Don't know how you'd get hot water.
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
because of that, i never push the hose back in. I just leave it coiled up in the locker. |
I have a fresh water washdown (has a 10Gal tank) and the tap is inside the boat below the middle seat at the stern mounted in the fiberglass. Uses a quick disconnect hose which you can easily remove. I guess the idea behind it was that it would be used more to wash the interior of the boat or other accessories that needs fresh water rinsing. Nevertheless, i still use it as a shower after a session before getting in the boat. I try to avoid getting salt water in as much as I can.
