Steam/smoke from under platform
While we were out the other day, my wife noticed something coming from under the platform area. She thought it was smoke, but I don't believe that's what it was simply because it didn't smell like smoke. I'm leaning more towards steam from maybe the coolant water being pumped back out??? I don't really understand how the whole marine engine totally works, but think I'm on the right track. Any suggestions to what I might be experiencing?
Really? I've never noticed it before.
Ok, great. Makes perfect sense. I'll watch it closely today, but I have a feeling it isn't going to do it. When it started doing it the other day, we had already been on the water about 6 hours. Engine was pretty warm.
Update. Out on the boat and the temp hit 200 and the engine light came on. Obviously overheating. What could be the problem? Would like to fix before the 4th.
Maybe your impeller is missing some fins?
Pull it out and check it.
"Hey baby want to make fourteen dollars the hard way?"--Rondhey Dangerfeild-Caddy Shack. "Was it over when the German's bombed pearl harbor ?" ---Animal house |
Where is it located? Raw water pump or circulating pump?
Raw water pump impellor
Check the raw water pump on the front of the engine just behind the pylon if its a direct drive. Chances are the impellor is missing a fin or two and you are not getting good water flow. Also, if you do find this to be the case, be sure to check if the fins are stuck in the transmission cooler since that is pretty common when the impellor starts to self destruct.
Good Luck.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile 2004 Prostar 197 - Red on White 350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun! |
#10
Just looked at your profile and see you have an X-30. The issue still sounds like a raw water pump impellor, and it is still mounted on the front of the engine, but it will be harder to get to on the X-30.
