Old 07-02-2011, 11:56 PM
tdrr tdrr is offline
Boat: 2008 X-2 MCX
Engine trouble '08 X2 MCX
Our first day out this season, the engine ran a bit rough to start, then eventually smoothed out but was surging a bit, especially around 3k rpm. That too improved a bit, but it could only turn about 4400 wide open instead of redline. I foolishly wrote it off to older gas from last season and high altitude.
Today, though, things got much worse. It started and seemed to be running fine during a run across the lake, but after getting the tube out and pulling the kids for a few minutes, "Service Required" showed up on the DIG and it really started surging and losing power. In neutral, it would run and rev smoothly, but when we started heading back to the ramp, it would barely go. Not sure if it was in limp mode or just running poorly. I experimented with turning the key and battery off then restarting. It ran well for a minute after that but then suddenly lost a bunch of power.
Pulling it to the dealer after this trip, but any guesses in the meantime? At the end of last season, it was last at the dealer for 100hr and winterization. Fuel pump/pressure?
Old 07-03-2011, 12:27 AM
Farmer Ted's Avatar
Farmer Ted Farmer Ted is offline
Boat: 1998 Prostar 190
try changing your fuel filters
Old 07-03-2011, 04:57 AM
peettee79 peettee79 is offline
Boat: 2010 X2
Water in fuel my guess.
Old 07-03-2011, 08:00 AM
ttu's Avatar
ttu ttu is offline
Boat: 2007 X2
looks a little familiar!
http://www.mastercraft.com/teamtalk/...ad.php?t=41614
Old 07-03-2011, 11:59 AM
xstarondabayou
Fuel Pump!
Old 07-23-2011, 11:53 PM
Boat: 2008 X-2 MCX
Distributor cap
Turns out it was a bad distributor cap put on at the last service apparently from a bad batch and is a national problem.
Old 07-24-2011, 12:35 AM
Jeff d Jeff d is offline
Boat: None
The '08 MCX isn't distributorless? My LTR is 8 years older and is distributorless.
Old 07-24-2011, 05:23 PM
Jerseydave's Avatar
TT Hero
No the MCX has a cap and rotor
Your engine has coil packs
I was njskier on here.
Old 07-25-2011, 10:46 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Glad it was an easy fix.
Funny huh, my '96 LT-1 was more high tech than my '06 MCX.
'06 X2 MCX
