Old 07-02-2011, 02:35 PM
durcanchris durcanchris is offline
Boat: 2006 X1
Boat died need some help 2006 x1
My boat turned off today in the middle of my set and wont turn back on. The ballast switches work but no buttons on the dash work, the gauges wont come on and the boat wont crank at all. Steps I have already taken are resetting the ignition fuse and all the other fuses under the steering wheel, checked all battery terminals, checked the fuse on the EMC on the engine and all the other basics. Any suggestions? boat is an 06 x1
THANKS!!
Old 07-02-2011, 03:19 PM
ttu's Avatar
ttu ttu is offline
Boat: 2007 X2
how about the reset button (or what ever it's called). located on the port side of the engine towards the front of your boat. here is a pic i took of mine.
Old 07-02-2011, 03:20 PM
Boat: 2006 X1
Yea,,,tried to push it in.....nothing. It wont push in at all.
Old 07-02-2011, 03:24 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
Check the wiring harness behind the dash. You won't believe how much stuff is back there. Check for any loose connections. Usually isn't enough strain relief on some of the major connections.
Will the engine turn over?
2006 Maristar 200VRS MCX
KGB Ballast and all the works!
Tow Veh: 2010 Toyota Tundra
Bike: 2007 HD Street Glide
Beer:Sam Adams Boston Lager/ Cherry Wheat, Petes
Strawberry Blonde, Petes Wicked Ale
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 07-02-2011, 03:28 PM
Boat: 2006 X1
Nope wont turn over, nothing happens when you turn the key in either position. The ballast switches still work, but nothing on the dash... bilige, aux lights etc do not work.
Old 07-02-2011, 03:31 PM
Boat: 2006 X1
I will try the wiring harness and let you know. Is there anything else you can think of to check? I have to drive to the storage work on it and want to have a couple of options when I get there. Thanks
Old 07-02-2011, 04:35 PM
vision's Avatar
vision vision is offline
Boat: 2008 X Star, 2005 X2
Gear shifter in neutral? I never remember if the neutral lock out switch also prevents power to the gauges.
2008 X star, 2005 X2
Old 07-02-2011, 04:41 PM
ttu's Avatar
ttu ttu is offline
Boat: 2007 X2
well you tried what i gave you advise. seems identical to what my issue was.
here is my link.
http://www.mastercraft.com/teamtalk/...ad.php?t=40709
Old 07-02-2011, 05:59 PM
Boat: 2006 X1
I will try all the idea that they mentioned. Where was your bilge switch located? On my boat only my 3 ballast switches below the throttle work. No switches on the dash work.
Old 07-02-2011, 06:51 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
There's a accesery(sp) breaker located by the battery.At least on my boat it is.
Reset the breaker by the battery.
Mine went out a few years ago.And none of the dash gauges worked.
---Animal house
