Old 03-21-2012, 11:36 AM
johnlanguab's Avatar
johnlanguab johnlanguab is offline
Boat: Barefoot 190, 89, Indmar 454
www.hot-spark.com is an option that may be more affordable.
Old 03-21-2012, 12:01 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
I was intending to do the EI conversion before figuring out that I have EI from the factory.
But my 91 PS has the screw down distributer cap, and skidim lists the Mallory EI kit, so that was what I was going with.
In all the reading I did, if the EI kit you buy lists "use ballast resistor", the NAPA IC64SB I listed does not require it. Its about $30.
The way I understand it, the coil is the one being protected by the ballast resistor, not the EI kit. So by buying the non - BR coil, you are covered from frying the old coil.
PS - Check amazon for EI kits, they are pretty cheap compared to everywhere else.
YMMV.
Old 03-25-2012, 11:41 AM
Matt L. Matt L. is offline
Boat: Mastercraft, 240SC, 1990, HO454 (425hp, 375???)
The ballast protects the points from getting too much voltage which causes them to arc and burn out.
I've been running a Pretronix Ignitor II for 8 years with an accell coil and was specifically told to remove the ballast.
Good luck! The Ignitor II was the best cheap upgrade I ever did!
Matt
Old 03-25-2012, 12:23 PM
pbgbottle's Avatar
pbgbottle pbgbottle is offline
Boat: 1988 tristar 190
thanks for your post Matt L i am looking at the igniter II also .but was wondering how long anybody has used one .8 years sounds good to me . i'll be buying it and giveing it a go .cheers
Matt
1988 mastercraft tristar (open bow).
