Old 06-30-2011, 08:45 PM
scocs15 scocs15 is offline
Boat: 2006 X2
Ballast won't fill
'06 x2 and the ballast tanks aren't filling. All the pumps work and all hoses appear to be connected. Do the hoses need to be primed to create suction? Any ideas why water doesn't seem to pump into the tanks?
Old 06-30-2011, 09:04 PM
73blue 73blue is offline
Boat: 2004 X-10
Changed the impellers lately? The pumps are self-priming so if they are working, its probably the impeller. Get the green replacements
Old 06-30-2011, 09:05 PM
DBrown2 DBrown2 is offline
Boat: 2005 MC X Star, PP
Agreed w 73.. go green and try bumping back and forth several times
Old 06-30-2011, 11:36 PM
kskonn kskonn is offline
Boat: 2003 X-30
x3 on impellers, usually the case as long as you can hear the pumps running.
Old 07-01-2011, 12:32 AM
willyt's Avatar
willyt willyt is offline
Boat: 2007 xstar
X4 greeeeeeeeeennnnnnnnn impellers. That or hit your fuses for the ballast pumps
Old 07-01-2011, 02:32 AM
nmcjr's Avatar
nmcjr nmcjr is offline
Boat: 2002 X-Star
If all the pumps are having a problem it sounds like it could be the check valves, assuming they were still used in 06. Find the hoses that are for the ballast drain from the manifold to the through hulls and see if you can blow into them. If so, it means they are bad, preventing suction from building on the water input line.
2002 X-Star
http://www.nopowerturns.com
Old 07-01-2011, 08:03 AM
Boat: Boat
Is the thru hull open?
Gone, surfing.
Old 07-01-2011, 08:11 AM
peettee79 peettee79 is offline
Boat: 2010 X2
Thats wat i was gonna ask.... Well?
