Old 06-26-2011, 11:37 AM
CapoReeder
How to remove dash gauge from 04 X-30
I need to replace the Perfect Pass display on my 2004 X-30. Do I have to pull the entire dash out? I started to take out the small allen head screws around the gauges but they appear to be cosmetic only.
Hopefully there is a trick to this. Thanks in advance for your help.
Old 06-26-2011, 01:22 PM
houtexX30 houtexX30 is offline
Boat: 02 X-30
You will probably have to pull the whole dash out. The allen screws are actually what holds it on but there are wing nuts on the back. You have to have someone access them from behind the dash through a relatively small opening in the fiberglass. Kind of a stupid design if you ask me.
hope this helps
Old 06-27-2011, 01:53 AM
kskonn kskonn is offline
Boat: 2003 X-30
Pretty sure it is the whole dash, it is on my 03.
Old 07-01-2011, 02:00 AM
CapoReeder
Thanks for the responses. Appreciate it.
Old 07-01-2011, 11:43 AM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
I changes the speedometer out for a PP gauge on my '00 230 VRS without removing the dash. I just laid on my back, reached up there and did it blind in about 8-10 mins. Not sure if yours would be the same though.
perfect pass, remove gauge, x-30
