Old 07-20-2011, 01:23 PM
tellimhesdreamin tellimhesdreamin is offline
Boat: 1990 prostar 190 Limited Edition
alarm cured
Just an update on the alarm. I put a new solinoid on and had to bypass nss to cure the starting problem.
anyway after that and checking all connections I ended uo just disconnecting the pink wire to board and it shut up. everything else is working perfect now.
I presume the boards just go bad after a while. most pcbs do eventually.
thanks for all the help!
Old 07-20-2011, 01:30 PM
temp guage pinging
The temp gauge was pinging because id accidentley disconnected the ground from back of temp gauge. Just thought id add that.
Old 01-30-2012, 11:21 AM
olianders64 olianders64 is offline
Boat: 89 tri star 190
I've replaced the solenoid, coil, and the circuit breakers. The Beep is still there. I've ordered another temperature gauge, but it hasn't come in yet. Hoping this ends the beeping. Any thoughts? Thanks
Old 01-30-2012, 01:21 PM
Yeah- none of those will cause the alarm to sound. The SENSORS cause it to sound, or bad wiring. Look for the boat wiring diagram for your model/year and find it that way. Using a parts cannon is just expensive and frustrating.
alternator, engine alarm, tristar
