  #31
Old 06-22-2014, 11:18 AM
bcd bcd is online now
Boat: 2014 X-2
it's a remote mount filter, so the gm block has nothing to do with the oil filter mount
Sent from my DROID RAZR HD using Tapatalk
Old 06-22-2014, 12:03 PM
$22 bucks at midwest mastercraft.. I spend $13 on a the NAPA Platinum 41060 - I know that most likely won't work. Do you have a caliper to measure the spin on nub and gasket size?
check this thread.
http://www.mastercraft.com/teamtalk/...p/t-56011.html
Old 06-22-2014, 12:38 PM
Table Rocker's Avatar
Wixfilters.com now shows a cross for the MV8V-1021. WIX 51372
http://wixfilters.com/Lookup/Interch...MV8V-1021&o=me
'96 ProStar 205 SD LT-1
Old 06-22-2014, 02:00 PM
which is Napa 1372 - Gold $6
which is Napa 41372 - Platinum $13
wix 51372 - $6
Fram PH2 - $4 (just kdding - don't buy)
Old 06-22-2014, 03:49 PM
KnoxX2's Avatar
KnoxX2 KnoxX2 is offline
Boat: 2014 MasterCraft X30
Ilmor oil filters
Is that for the ilmor 5.7?
Old 06-22-2014, 04:13 PM
same oil filter all engines... http://www.waterskis.com/PV05738-p/ilmor_oil_filter.htm
Old 06-22-2014, 05:11 PM
KnoxX2's Avatar
Thanks Mike
Old 06-22-2014, 05:37 PM
cwarndahl's Avatar
cwarndahl cwarndahl is offline
Boat: X-45 finally better then x-10
I just used the Mobil 1 m1-210, fit justifiable but it is 13 buck. How ever how are you all changing your oil. My pella 6000 pile extractor wouldn't fit down the dip stick hole.
2012 MC X-25
Old 06-22-2014, 06:09 PM
KnoxX2's Avatar
I have not changed my oil yet on the 2014 X30 but on my 2006 X2 with MCX there was a oil drain hose that came off the oil pan and was long enough to fit out the transom drain plug. Is this not the case on the Ilmor's?
Old 06-22-2014, 06:25 PM
cwarndahl's Avatar
Well on the older 01 x-10 I just drained through the dip stick hole. I just realized I better check my spelling because the auto correct makes that last post terrible!
2012 MC X-25
