Old 06-14-2011, 08:55 AM
hragsarkissian hragsarkissian is offline
Boat: 2010 X25SS
2010 x25 rubber plug/outlet
hi guys,
i recently got a 2010 x25ss with 50 hours on it. Its been running great so far. Although i was wondering if anybody had an idea with the plug on the right side of the transom above the swim platform is. Ive searched around on the forum but havent found an answer. from what i understand the drain plug would be im the center beneath the platform so Im assuming thats not it. it even has some threading to screw some kind of hose or something.
thanks,
hrag
Old 06-14-2011, 09:03 AM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
congrads on the purchase.
your plug sounds like the flush kit. would help if we had a picture.
do you run in salt water?
Old 06-14-2011, 09:15 AM
jstewart319's Avatar
jstewart319 jstewart319 is offline
Boat: Use to own Mastercraft X-25 2010 MCX
Sounds like your talking about the flush kit the arrow shows where mine is located on my 2010 X-25.
Old 06-14-2011, 09:16 AM
Flush kit.
Here is mine:
Old 06-14-2011, 09:20 AM
Boat: 2010 X25SS
yeah its docked in the marina here. the boat is a saltwater series. has an indmar mcx with fesh water cooling( closed), hydraulic steering and other ss perks. i was also think it might be a flush port but wasnt sure.
here is a picture, might be a little hard to see but its between the stereo remote and hook.
Old 06-14-2011, 09:22 AM
Boat: 2010 X25SS
great,
thanks guys. how often do you recommend to flush the engine considering i have an SS engine?
hrag
Old 06-14-2011, 09:24 AM
everytime. does your boat sit in salt water?
Old 06-14-2011, 09:26 AM
Boat: 2010 X25SS
yes it does. i figured i shouldnt have to do this if the engine was geared for it. but it seems to be otherwise.
Old 06-14-2011, 11:05 AM
MC X-15's Avatar
MC X-15 MC X-15 is offline
Boat: 2008 Mastercraft X-15 SS
Flush after every use. I would also suggest pulling it from the salt every week of two and do a full cleaning. Even on salt water series the salt will hurt the boat. I have an 08 stored on a lift above brackish water. I flush and wash after every use. Still seeing some signs of salt corrosion. Spend the time and your boat will last alot longer.
Old 06-15-2011, 01:58 AM
Boat: 2010 X25SS
Thanks for the tips. I'll def keep that in mind. I would have to get the flush kit now correct?
platform, plug, transom
