Prop Install
Putting a new prop on-Anything I should do other than slide on and tighten nut? Also, I nicked the old prop and was wondering (don't think there is happened while trailering boat) but if there is a shaft issue what should I look for other than vibration?
thx |
Might want to apply water proof grease to prop shaft where prop goes, will make next removal of prop a breeze...
remember to install a cotter pin after nut is installed too!
Stainless cotter pin is necessary too...
It should be obvious, but be sure to use a stainless cotter pin too not a coated steel one or it will rust away on you.
Edit … (damn, Willy just beat me to hitting the post reply button)
1998 30th Anniversary ProStar 190 - Corvette LT-1 w/PowerSlot .................. Hang On! ![]() Last edited by SS LS1; 06-09-2011 at 09:43 AM. |
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#7
Thanks guys!!!! I assume the new prop just slides on the shaft-is there a need to align anything up in particular?
thx again!!! |
#8
If its splined Just slide it on and tighten nut and insert cotter pin, if it has a keyway line up slot on prop and continue installation...
James 1989 MasterCraft TriStar 190 SE |
#9
What jmcreight said.......
There is a torque spec, but I just tightened mine relatively tight (no impact or breaker bars, just as tight as I could get it by hand with a box wrench. Note, if you have a tapered shaft, it's reccomended to use a little valve grinding compound between the prop and shaft. Spin the prop a bunch of times to let the compound "smooth" out any imperfections to ensure that it seats 100% on the shaft.
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
#10
You do NOT want to be putting grease on a tapered shaft. The prop relies on the taper to stay on- hence the valve grinding compound. Test fit the prop without the key first, and make sure you get it all the way back to that point when reinstalling with the key. You dont want to be binding on the keyway.
PCM 351w, 350hp |
