1996 LT1 Fuel Filter Part # ?
I need a new in-line fuel filter for my 1996 PS 190 w/ LT1 and I am not close to my boat to look at the part number. I want to buy one at a parts store on my way home from work today. Does anyone know the part # ? Cross reference part #? I thought I remembered it as a AC Delco GF652 an or Wix 33481 ? Are those the right part numbers ? Thanks for any help on this.
I think you have the correct numbers. When I canged mine on the 97 ps205 they crossed it to a purolator F33144. This link includes the AC delco nad Wix numbers also.
http://oem-engineering.com/products/filters.html |
Not sure if yours is different, but my 98 has two filters. One of top of the tank, one on the back of the engine by the ECU. If i remember correctly they are identical.
they're both in my signature
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
I just installed Wix 33481 at both locations on my ' 98 LT-1.
1998 30th Anniversary ProStar 190 - Corvette LT-1 w/PowerSlot .................. Hang On! ![]() |
Thanks for the help / info. everyone, unfortunately I am still at work and will have to buy it tomorrow.
I have never used a Wix filter, are they good filters? How much are they? |
JLeuck64,
I can not find either of those filters using the part numbers: AC Delco 25171391 & 89058397 in the ACDelco on line catalog. Are those ACDelco numbers? |
My '96 LT-1 has the following WIX filters
On top of the fuel tank: 33003 (clear plastic) or 33482 (steel) in line with hose clamps on each end. Screw on fuel filter: 33481 on the fuel pump. |
I purchased those filters using the AC Delco numbers from a GM dealer back in 2007 so IDK why the are not showing up in the online catalog... sorry.
Thanks for the Avatar pic Pat! That should keep any man smiling all day!
#10
Here is what I found for my 94' LT1:
Main Fuel Filter – Napa FIL 3481 Tank Fuel Filter – Napa FIL 3482 -------------------------------------------- Front Part: FIL 3482 Product Line: NAPA Filters Price Unit : : 9.69 Features & Benefits NAPA Gold Fuel Filter - NAPA's Best Quality; 13 Micron Attributes Fuel Filter Height (Inches) : 5.546 Fuel Filter Height (mm) : 140.87mm Fuel Filter Inlet Thread Size (Inches) : 3/8 Fuel Filter O.D. (Inches) : 2.16 Fuel Filter O.D. (mm) : 54.86mm Fuel Filter Outlet Thread Size (Inches) : 3/8 Fuel Filter Style : Fuel (Complete In-Line) 3481 NAPA Gold Fuel Filter ------------------------------------------------ Part Number: 3481 UPC Number: 765809153257 Principal Application: GM Models (83-06), Jaguar (97-06), Land Rover (99-04) Style: Fuel (Complete In-Line) Filter Service: Fuel Height: 4.290 Outer Diameter Top: 2.170 Outer Diameter Bottom: Closed Burst Pressure-PSI: 300 Max Flow Rate: 1 - 2 GPM Nominal Micro Rating: 4 Gasket Diameters Number O.D. I.D. Thk. None Price USD $ 9.41 Shipping Weight: .50 lbs.
- Jeff 1994 205, LT1 |
