Old 06-06-2011, 12:56 PM
dgaugler's Avatar
dgaugler dgaugler is offline
Boat: 1996 Maristar 200 VRS
Will this
I'm looking at upgrading the original alternator to support all the additional accessories. I was going to just have it rebuilt locally but it looks like I can buy new one for less.
Will this alternator work on my '96 Maristar 200? (NOT the LT1 engine)
Delco Marine Alternator Mercruiser 3-Wire 105 AMP
http://www.amazon.com/Delco-Marine-A.../dp/B003Q7V2DS
Anyone else used these alternators? I'm surprised at how cheap they are. It looks like it would fit by looking at the pictures but I'm not positive.
Old 06-06-2011, 02:08 PM
1redTA's Avatar
1redTA 1redTA is offline
Boat: 1981 MasterCraft Limited 351W slot
I just bought a similar one wire 105amp for my 81 to replace the 35amp and used amazon as well. It looks to be good for the little cash I spent, about $70 shipped, which was cheaper than having the alt shop rebuild the factory one for $120ish. I have not been able to use it yet since we are moving
1981 MasterCraft
19' Skier 351W PowerSlot Deluxe
Long gone is the Trans AM
Old 06-06-2011, 02:22 PM
Gofast's Avatar
Gofast Gofast is offline
fit?
OK, I had a similar altenator built for my 95 Maristar. I have the LT 1 though. Went from 50 amp alt to 105 amp. The wiring all matched my factory unit....
However, the issue I had and you will probably face is the case was a bigger diameter than the lower output case. I had to modify my brackets to hold the larger alt. It all looks factory now, but the mounting was a test of fabrication skills.
I did this 2 summers ago and do not regret it one bit.
Rob
altenator, maristar
