Old 05-24-2011, 10:31 PM
msubryan
Trailer Tire Flies Off at 55mph
Any idea what would make a wheel break all 5 lugnuts and fly off while going down the road?
Pretty scary stuff, especially when it is hauling my baby!
Old 05-24-2011, 10:36 PM
Yeah- it was torqued on too tightly. How long are the remnants of the studs? Does the break point look like it was corroded?
Old 05-24-2011, 10:43 PM
msubryan
The lugs had not been torqued in over a year or so. The breakpoint was 3/8" from hub, right in middle of wheel...3/8" from lug nut..(I Found 1)...
Old 05-26-2011, 04:25 PM
afkvrts's Avatar
afkvrts afkvrts is offline
Boat: 225 vrs
Ive seen it happen on a fishing boat.
The lugs were rusty and when we hit a bad pot hole in the asphalt at 55 mph - the freaking wheel came off.
Sucked - cause it was a single axle trailer and we were forced to call a tow truck
Old 05-26-2011, 05:49 PM
ahhudgins's Avatar
ahhudgins ahhudgins is online now
Same thing happened to be on a long road trip. I had repacked my bearings on the single axle trailer before we left and I checked the torque on the lug nuts several times during the trip. I hit a massive pot hole about 50 miles from my destination and about 5 minutes later the whole wheel flew across the road right in front of a state trooper (and I was speeding at the time). The trooper found my wheel/tire and didn't write me up, I guess he felt sorry for me. Two of my studs had obvious old rusty cracks in them and the pot hole finished them off. I had an extra spindle and jack with me so I was back on the road in a few minutes with a messed up trailer fender.
Old 06-18-2011, 06:26 PM
nbkdaw3 nbkdaw3 is offline
Boat: X-1 2007 & 2009 197 2009 & 2006
wheel flys off
I had this happen but instead of going 55 i was going 70+ shot off like a cannon right through the fiberglass runners and flew in the air straight up I bet 30 feet. Never found tire and just gald no one behind me did not freak out and get hit. How did it happen? A few days before my brakes had been locked up so I took the tire off and got the brakes realesed by removing the calipers. I remembered afterwards I had only tighten the bolts up while the boat was not on the trailer and the tire would spin when i was trying to get them supper tight. In all the other packing I forgot to tighten before we left with the boat on to hold the tire steady. I took off from Fl headed back to NC with the boat and made it about 1 hour north of Orlando before it came off. I suspect one by one the nust got loose and the rim sheared each lug off till it came off. I learned a valuable lesson. I never head very far with my trailer without a full check of of the tires and the lug nuts. I believe your lug nuts were lose and the same thing happened.
Old 06-18-2011, 06:35 PM
Too tight or too loose will have the same effect. The same thing can happen if you don't use a star pattern when initially seating the wheel. If the wheel is not square to the wheel flange, it will soon work itself loose and make an exit. This happened to my F150 when I let my brother put a rear wheel on following a brake job.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 06-18-2011, 08:40 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Lug nuts probably loosened up, sheared a lug followed by the rest.
'04 MariStar 230VRS/MCX
Old 06-19-2011, 12:45 AM
Maristar210 Maristar210 is offline
Boat: 04 210 Maristar
Your lug nuts came loose and the tire left the fasade.......
Old 06-19-2011, 08:58 AM
woobiedmd's Avatar
woobiedmd woobiedmd is offline
Boat: mastercraft PS190 1988 351
Roger the loose lugnuts. Last year after replacing a broken leaf spring on a 20+ yo trailer, I had the same thing happen. I had never re-torqued them. All the bolts sheared off and you could see how rusty they were. To add insult to injury, the boat and trailer slid off the side of the flatbed. What a mess and a valuable lesson. Now I have new hubs, rims/tires all around and I always check the torque before going anywhere! If I could figure out how to make my pix smaller, I will post pix of this installment in the "Adventures of Boating" saga.
trailer, wheel
