#31
That mangy gasket and sinking float I really think is an ethanol problem. It eats plastic, and the coating off the nitrophyl float. I have to overhaul once every two years. With ethanol percent slated to increase in gas, the problem is not going to go away even with your new carb. You might as well learn how to overhaul. I doubt if the gasket material let go into the bowl. At the end of the season, dump the fuel out of the carb at layup. Replace the bowl contents with avgas or kerosene, just dump it before the next season.
#33
There is a Filter in your Fuel Pump as well... Make sure you check that too...
#34
I know about the screen going into the carb and the filter on the water/fuel separator prior to the fuel pump- I've never heard of a filter in the actual fuel pump-what gives?
#35
Been down your path earlier this year. If you bolt your new carb on and it dies instantly when going for the holeshot you got my old carb, send it back and buy a new one. Advance Auto when you go online had the best deal I could find for a new Holley 4160. |
#36
Hope you get it running good with that new carb.
I've had a lot of power valves go bad on my holley equipped truck in the past. It does the same thing, drips gas right down the inside of the carb while at idle. BTW, where do you ski? I'm on the Delaware river in Florence NJ. (I sent you a PM)
I was njskier on here. |
#37
I'm out of Chalfont- near Doylestown. We usually go down to the Bohemia river(upper Chesapeake). I would need your guidance to hit the Delaware- 3 years in a row-bent nonrepairable props, I just installed a depth finder. Now I will know how deep the water is when I hit my next log!
#38
Just curious to know how yor progress is going towards getting your boat up and running?
#39
Thanks for checking. Still waiting for a rebuilt 4160 from National Carb. Ordered last Thursday, was supposed to ship out yesterday, now shipping "early next week". The guy said the marine section is swamped. I don't mind waiting as long as quality doesn't suffer. I'll keep my fingers crossed and will post with results.
#40
I agree. I had the same problem on an older boat and the float was sticking and causing the engine to flood. Sounds more like a carb problem than a wiring problem.
Love my boat, hate my trailer. |
