Old 05-18-2011, 11:18 PM
davomaddo's Avatar
davomaddo davomaddo is offline
Boat: MasterCraft, X-15, Salt Water, 2009
Help - is this a big issue or not
Sorry if I don't have the terminalogy right.
I assume I need my dealer to fix this. I am wondering if anyone can help me know if this is a major repair and if you know why this happened.
I have a X15 2009 Salt Water Series with closed cooling.
There is a crack in what I think is the muffler. I have attached pictures below. I believe it is fiberglass.
Water only leaks when the boat is in the water. When I run the boat hooked to the garden hose, it doesn't seem to leak..
Below is a general picture of the area. The crack is actually hidden from this view, but I circled the area it is;
Below is a close up of the crack. The crack is about an inch long:
Here is another picture.
Thanks for the help.
I will take the boat in to the deal, but it would be nice to know how complicated this problem is to fix and what why it occured.
Old 05-18-2011, 11:30 PM
wakecumberland wakecumberland is offline
Boat: 2010 X25
Looks like part of the muffler to me. I believe those are fiberglass, so it should be an ez repair. But I've been wrong before
Old 05-18-2011, 11:43 PM
davomaddo's Avatar
Yes, it isn't metal - most likely fiberglass.
Any clue why it would have cracked?
Old 05-19-2011, 08:16 AM
bturner2 bturner2 is offline
Based on where It's located (on a seam) looks to be either a manufacturer defect or freeze damage. Based the time of season I'd say it's more likely the later. I don't know what these mufflers look line internally and if there could be any internal damage but to fix just the crack I would give Marine Tex or Fiberglass a shot. If I were going to try to fix it I'd use a Dremel or die grinder to open up / clean out the crack and then fill it with Marine Tex.
http://www.marinetex.com/
Old 05-20-2011, 08:55 AM
davomaddo's Avatar
I took it in and it is a cracked muffler. It should only be about 2 hours to replace and $200-$400 to either recondition professionally and tested or buy a new one.
Old 05-20-2011, 09:34 AM
Kingsley X-1's Avatar
Kingsley X-1 Kingsley X-1 is offline
Boat: '08 X-1
that is what i would do and then hit it with a bit of flat black spray paint...you would never know it even happened.
Old 05-20-2011, 10:00 AM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
X2 on self repair.
Fiberglass resin with some kitty hair. Sand area first then lay kitty hair or woven fiberglass around muffler, then apply resin. Sand any runs out and paint. Its a quick $30 fix that will be permanent.
Rollin' Gangsta Style
