Perfect Pass pull characteristic
Does anyone know what/how adjustment need to be made to PP to allow for a stronger hole shot to pull fat arse out of the water? Right now wife hits the throttle and i drag a good bit before getting up. With PP off it is easy for her to get me out. I am referring to slalom mode.
David 2008 X2 MCX ![]() 1999 Maristar 210 (sold) 1996 Bayliner 2050 |
Reprop it. Has nothing to do with pp
Should have nothing to do with prop if it works fine when PP is off. Sound like a PP program issue, however I am the first to admit I know nothing about PP.
Correct it is not a prop issue and i know you can adjust the pull just need some help with what adjustment others might consider.
There is no adjustment in Perfect Pass that has anything to do with the hole shot. Perfect Pass isn't even engaged at those rpms. The adjustments in the pull, i.e, Kx values, change how rapidly Perfect Pass adjusts the throttle when it is controlling the system (ski speeds). The result is a firmer or softer pull. If the KX values are low, the rpm's will swing more and the pull will feel soft and easy but the boat will run with the skier into the pre-turn. If the KX values are high, the skier will feel completely free from the boat in the preturn but will feel no give in the pull off the ball.
1996 ProStar 190 Still slummin' behind PP Chippin' away @ the BLUE LOOP |
#7
You may actually want to ask your wife not to hit the throttle but to ease you out. Sounds counter intuitive, but it is actually easier to get out of the water with a slow steady pull than a hard fast pull. Try it once...I think you will be converted.
1995 Prostar 190 Remember, we must share our waters and be respectful of other boaters. Rude people suck!
#8
#9
Just a question. But are you using the PP on your X2 for skiing?
Gone, surfing. |
#10
Show-Off...........
___________________________________________ ________________________________ |
