Old 05-06-2011, 02:27 AM
ACM197
2006 Pro Star 197 "Swimming" tracking issues at higher speeds
On my 2006 197; MCX w/ 1:1 and ACME prop, at higher speeds and flat water, it slowly starts to drift/swim/float a little to the right and left when pulling a footer. This problem is intermittent--not sure if it has something to do with the slow current and angle of attack, or a possible bent rudder? Has anyone else experienced this and found a solution? Thank you
Old 05-06-2011, 07:58 AM
jkski jkski is offline
Is your rudder "loaded" (ground on one edge) at all? I can recall a similar feeling from some of my 197's on nice flat water until I loaded the rudder to place a slight constant tension on the wheel.
Old 05-06-2011, 10:17 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Check your tracking fins. Maybe one of them is bent.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 05-06-2011, 10:24 AM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Exactly. If the rudder is "neutral", it does tend to fishtail a bit.
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 04-21-2015, 06:38 PM
barefootnaked barefootnaked is offline
Boat: mastercraft, prostar 190.1993
ifni want it to track right which side of the rudder to grid down and how much
Old 04-22-2015, 07:55 AM
When looking at the rudder from the rear, I grind the right side trailing edge which makes it such that the boat pulls to the left if you let go the wheel so when course driving it has a constant pressure turned to the right. My advice if you have never ground a rudder before is to grind it evenly down the one side a little bit and then test as you can always grind more but can't put it back on (yes, you can always grid the opposite side to cancel out if need be).
Good luck and hope this helps.
Old 04-22-2015, 03:42 PM
CCAnderson's Avatar
File, Don't grind
Use a file to tune the rudder. Grinding removes material very fast especially in soft materials like those used for our rudders. You only need to remove a bit of material which only took me maybe five minutes. I took off a wedge 1/16" deep and 1/2" long which gave plenty of "load".
drift, drifting, rudder, steering, tracking
