Old 05-02-2011, 07:34 PM
jdeml jdeml is offline
Boat: 2004 Xstar
wiring 3 batteries
So just wanted to double check before I start this process. I am repairing the damage from thieves in the near future. Have 3 batteries with a perko and black block (isolator?) in my 04 Xstar. I plan on wiring crank battery to pos 1, and the 2 other deep cycle batteries linked parrallel to pos. 2. Is this correct? I was wondering if linking the deep cycles in parrallel with 2 guage would be ok. I am running 3 amps off the deepcycles and know all those wire guages. Any yeah or nieghs is appreciated. Or better yet diagrams. I see alot on 2 battery setups and this makes sense to me. What do yall think. Thanks
Old 05-02-2011, 09:00 PM
airdrew99's Avatar
airdrew99 airdrew99 is offline
Boat: 1991 Mastercraft Prostar 190 351W w/ powerslot
Just my 2 cents: On my F-250, I have two batteries that are hooked in parallel all the time (they are not isolated by any kind of switch). When one battery dies (not gets low on charge, but dies), it will take out the other battery that is hooked in parallel with it. Ask any diesel truck driver that has two batteries. One of our rules is that the batteries have to be replaced in pairs to help keep this from happening. Like I said, just my 2 cents. I hope this helps.
Drew
Boatless 'til I get out of school.
Old 05-02-2011, 09:04 PM
Boat: 2004 Xstar
Drew
That is correct, that is why im wondering if I hook both deep cycles (stereo) up in parrallel then if I ever did run down my stereo I would always have the switch to flip it to my starting-cranking battery and could make it home. Basically Ill be listening to music alot parked and instead of just one battery I was just gonna link another to make it last longer. Will always charge the deep cycles back at home as the alt wont prolly get that done.
Yellow X9's Avatar
Yellow X9 Yellow X9 is offline
Boat: Mastercraft X-9 05
I have 3 batteries in mine, and wired just like you describe above, I leave my Perko on the all position all the time with no issues.
Old 05-02-2011, 09:28 PM
Boat: 2004 Xstar
Thanks, thats what I needed to hear. Also what guage did you use to run them in parrallel?
Old 05-03-2011, 01:04 PM
craig3972's Avatar
craig3972 craig3972 is offline
Boat: 2006 mastercraft x-star
I have a small blue top and a set of booster cables - works well on other boats without power.
Old 05-04-2011, 01:58 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
2ga is sufficient.
'06 X2 MCX
