Old 04-27-2011, 02:40 PM
TayMC197's Avatar
TayMC197 TayMC197 is offline
Rudder Shaving
It was pointed out to me that I need to file my rudder to help prevent it from pulling so hard when driving at towing speeds. I looked at it from the back of the boat the other day and the right side of the prop is worn to a rounded edge while the left side still has a nice edge. Any advice on this?
Currently its pulling well more than usual to the right. No slack in the cables, not bent, etc...
Old 04-27-2011, 03:08 PM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
Go to this ski site: http://www.thewaterskiforum.com/forum.html
and enter Rudder Grind in the search menu. It will give you some good ideas of what is going on with your boats rudder.
Old 04-27-2011, 03:12 PM
flipper's Avatar
flipper flipper is offline
I'd say don't do it, but if you must here is how
'91 prostar 190
Old 04-27-2011, 03:19 PM
I would lean toward caution, I would not do it yet. Without pictures of the rudder, it sounds like it has been ground on already. The discussion on the water ski forum will give you everything to look for.
Old 04-27-2011, 03:25 PM
flipper's Avatar
They come like that, you grind the other side to take the pull out of it.
'91 prostar 190
Old 04-27-2011, 03:39 PM
Without pictures it is hard to say. If someone has already shaved the right edge off / it has been rounded and you then shave the left side of the rudder, you are going to have an whole different issue. With a LH rotation you do not shave the left side, you shave the right side.
Old 04-27-2011, 04:01 PM
flipper's Avatar
That somebody was at MC, just like all the other '92 PS 190s came like that. You take a tiny bit off the left side if you don't want it to pull any more, or you want it to pull less.
'91 prostar 190
Old 04-27-2011, 04:04 PM
flipper's Avatar
Ooops...............
'91 prostar 190
Old 04-27-2011, 04:08 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Easy to do with a flat file. Personally I ground mine to get quite a bit MORE pull to the right.
Old 04-27-2011, 04:56 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
If you let go at speed and your wheel doesn't spin, there isn't enough pull.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
