Old 04-18-2011, 04:23 PM
jconover's Avatar
jconover jconover is offline
Boat: 1988 ProStar 190/454HO
Supposed to just be riveted together. Based on my own scraping and cleaning, I think there may have been a thin bead of better quality sealant applied at the factory right before they set the top on the bottom, but it was only on the outside facing edges.
Prior owner applied liberal (sloppy) amounts of a clear silicone adhesive. It was total, utter crap.
Old 04-19-2011, 11:55 AM
89BigBlock's Avatar
89BigBlock 89BigBlock is offline
Boat: 89 prostar 190 454
Wow! big props to you sir! I have an 89', same color, same motor.
Q: How difficult was it to get the exhaust out? From you pics and what I've seen on mine, it looks like just the four screws in the transom and dissconnecting the rubber. I'm assuming the beauty ring is also siliconed on.
Old 04-19-2011, 12:01 PM
jconover's Avatar
Inside - one clamp on each 4" exhaust vent, hose was stuck on pretty good, but nothing that a few grunts couldn't take care of.
Outside - 6 screws on the 4" exhaust, and it was adhered to the boat with whatever strong sealant they used in 1988 - it was NOT just silicone, but a hybrid silicone-epoxy type substance. I used a razorblade and a scraper to cut down next to the exhaust ports and crack some of the material. It actually came away from the metal easier than the gelcoat. Took me maybe 45 minutes per exhaust port to separate the through-hulls from the hull. Once I had it sufficiently loosened up, a rubber mallet applied from the inside allowed me to push it out the rest of the way.
Old 04-24-2011, 06:16 PM
jconover's Avatar
Was a good weekend to get some work done. Got all the paint sanded off, and started working on bringing the finish back up on the hull
This is after wetsanding 600 grid (to get the paint off), 800 grit (to get rid of the 600 grit scratches), and compound buffing with 3M Imperial Compounding and Finishing Material.
Still need to finish polish with something finer, but it came up pretty sharp!
Before and after - caught the kids in the reflection too ;-)
Old 04-24-2011, 06:54 PM
SPSinclair 190 SPSinclair 190 is offline
Boat: MC Prostar 190 1993 351 PP RED AND WHITE
Looking awsome
Old 05-14-2011, 08:33 AM
woobiedmd's Avatar
woobiedmd woobiedmd is offline
Boat: mastercraft PS190 1988 351
We need an update! More pix! By the way, it looks great so far! You are very brave to go this far. Keep going- the weather is warming up!
Old 05-14-2011, 11:26 AM
03geetee's Avatar
03geetee 03geetee is offline
Boat: 1983 Skier 190 Stars and Stripes
Great work brother that is inspiring!
JTR
1983 MasterCraft Stars and Stripes
Cream/Red Metal Flake
"Powerslot"
"The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish."
-Charles Chaplin-
Old 05-14-2011, 12:08 PM
Hoosier Bob's Avatar
Hoosier Bob Hoosier Bob is offline
Boat: 1993 MASTERCRAFT PROSTAR 190 285HP 351 INDMAR
Very cool for sure. I used stainless bolts and locknuts to reaffix my deck. Pain but tight as a drum. Oh, if you hit something rivets pop, bolts don't so don't hit anything.
BAREFOOTING: I knew it was gonna hurt when I felt my arse cheeks hit me in the back of my head!
!UOY NAHT RETSAF MA I TUB KNURD EB YAM I
Old 05-15-2011, 12:45 AM
jconover's Avatar
Pieces parts are at the powdercoating place - when I stripped the starboard side of the boat I found some fairly major gelcoat damage - decided to take it to a local pro to do that work - the gelcoat bubbled when i put the heat gun on it (i'm guessing water got behind it). Work should be finished next friday - they've been working on getting a good color match, turns out that's a bit touchy on the black and gray.
I have a huge list of things to do when I get the hull back - starting with mounting the NDT tower and installing the new stereo from Earmark, plus of course reinstaling all the hardware. Will post more pics when I get her back.
Old 06-01-2011, 02:30 AM
jconover's Avatar
Some metal bits from the boat, back from a quick Aluminum Oxide blasting.
