Old 04-10-2011, 10:15 PM
bjw444 bjw444 is offline
Boat: nautique and hopefully xstar soon
what ballast bags should i buy
Ok I removed my hard tanks from my 02 xstar and want to put larger bags in.
Question is should i buy a pair of 500lbs bags?
or a pair of 750's?
The pair of 500s is like 199$ and each 750 is 150$
thanks any i appreciate it!
Old 04-10-2011, 10:40 PM
73blue 73blue is offline
Boat: 2004 X-10
I think the pair for 199 is actually 400lb each. I was thinking about piggy backing those onto my factory tanks in my 04 x-10. If you already have the factory tanks out, I'd probably go with the 750lb bags
Old 04-10-2011, 10:47 PM
do you know what the capacity of the factory hard tanks are?
Old 04-11-2011, 09:15 AM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
Depends on what you have up front. I'd think the 400s would be sufficient for wakeboarding but if you want flexibility for surfing the 750s would give you that.
If you wanted to try to utilize close to the full capacity of those 750s for wakeboarding then you will probably need more than stock weight in the bow. The Fly High integrated bow sac might get you there but you might need more than that unless you're ok with putting the sac on top of the seats to get the full 650 lb capacity out of it.
Old 04-11-2011, 09:18 AM
Boat: 2004 X-10
The factory hard tanks are 250lbs each I believe
Old 04-11-2011, 09:42 AM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
Search on x1/old xstar/X2/prostar 205V wakeboarding setup. I have the same hull (05 X2) run 750's in the back, 500 in the ski locker as the kgb and 300 on top of that in the walkway with 200 lbs of lead in the very front of the boat. When I come back next season from my ACL repair, master plan is to keep that setup, add 100lbs of lead to each locker floor, and add the intergated bow sac below the seats in the bow. ran something like that this summer, the wake was absolutely ridiculous.
Old 04-11-2011, 12:39 PM
Boat: 2000 230 VRS
Whoa! That's gonna be over 3k. What doesn't kill your knees will only make them stronger, right?
Old 04-11-2011, 12:41 PM
brucemac's Avatar
brucemac brucemac is offline
i would buy the 750's and not look back.
íViva 205v!
2003 X-2 MCX
Old 04-11-2011, 05:21 PM
Ya I will do that for sure
Old 04-12-2011, 08:04 AM
mccobmd's Avatar
mccobmd mccobmd is offline
What he said, I put the 750's in and they work great, have never looked back from that.
