Old 04-10-2011, 06:07 PM
mike9826
08 X45 SS, LY6, Coolant coming out of exhaust
I just had a new LY6 long block installed by our local Nautique shop, and I got the boat in the water for the first time and noticed the temp gauge starting to rise so I shut down the engine and ran to get some more Dex-Cool. I just figured they didn't purge the system well. I ended up adding another gallon of coolant while trying to burp the system and this thing just kept taking what ever I could put in it.
I pulled the boat out of the water and hooked up the boat to the flush kit. I noticed coolant came out of the port side exhaust. I pulled the hose loose that comes off of the heat exchanger and goes to the bottom side of the exhaust flange that goes to the exhaust hose. There was also red water in there. Has any one else had this happen? I think I have it diagnosed down to a bad heat exchanger, but it is hard to 100% sure. The hoses look like they were all installed properly, but if anyone has access to a Indmar service manual I would greatly appreciate a diagram that would show the proper routing just in case.
Thank you!
coolant, exhaust, heat exchanger, ly6, x45 ss
