Old 05-12-2013, 11:35 PM
Miss Rita's Avatar
it looks like you put the 'Y' pipe on the wrong side of the raw water pump. It should be placed on the intake side where the pressure will be low so that extra water flows through the heater system.
OK, someone needs to explain to me how putting the cold water supply to the heater core on the suction side of the raw water pump will provide any cold water whatsoever. It would seem that if installed that way the impeller will suck water backwards through the heater core. Also, shouldn't there be a mixer valve to mix the cold and hot water together for the right temperature?
Old 05-13-2013, 03:47 PM
190 Skier's Avatar
190 Skier 190 Skier is offline
Boat: MasterCraft, PS 190, 1990, 351 windsor
Water Pump on the Engine
The Y-Tube is to return the hot water that comes from the heater core back to the engine where the water pump on the engine circulates it thru the heater core again. The heater works great when plumbed in this configuration and blows plenty of hot air.
Old 05-13-2013, 03:58 PM
Miss Rita's Avatar
OK, makes more sense. I was thinking the Y-tube was cold water supply, not warm water return. Thanks for the clarification.
My other boat has a shower, uses cold lake water mixed with warm engine water in the right proportions to make a nicy comfy rinse. I suppose a heater doesn't need any mixing valve, just the Lo-Med-Hi fan speed.
Old 07-14-2016, 07:19 AM
Marius Titulescu Marius Titulescu is offline
Boat: none
I confirm. Works like a charm.
_____________________________
Marius
PVC panels
Old 07-14-2016, 08:31 AM
jackpita jackpita is offline
Boat: 2008 X14. Sold Maristar 210, 1992, 351
Send a message via AIM to jackpita Send a message via Yahoo to jackpita
See this link on y-pipe install.
http://www.mastercraft.com/teamtalk/...heater+install
