Old 03-14-2011, 11:11 PM
mcboi52 mcboi52 is offline
Boat: '89 MasterCraft Prostar 190
Angry Starter Question
Recently (January), I bought a '89 Prostar 190 from the original owner. I ran it out at the lake twice, then the starter decided it didn't want to engage anymore and just spun. Within a day or so, I went and bought a new starter identical to what was on there. Now, 2 months later...same thing. It did start at first...buzzed around the lake for a little while, went back to pick someone up to take out, and that's when it just spun again. It's a horizontal mount (if that matters). Am I supposed to spray something like WD-40 in the starter or is this a common problem?
Even after tapping on the starter a few times with a hammer to see if it would do anything...nothing.
Old 03-14-2011, 11:33 PM
oldairboater's Avatar
oldairboater oldairboater is offline
Boat: Mastercraft, Prostar, 1992, 351 Ford
Tap the starter lightly at only the bendix or the end plate if you must. Sometimes tapping seats the brushes if they are hanging. That doesn't sound like your problem. Stay away from the sides where the magnets are. If it was me. I would pull the starter off and grease the bushings and bendix shaft. WD40 is junk in my books and I only use it to clean mud off of my shotguns and displace water off of my reels before I oil with appropriate oil. I usually get my starters rebuilt from a local shop. I think that is better then new junk or rebuilt junk from a parts house. JMO.
Old 03-14-2011, 11:36 PM
You would do well to heed the above advice.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 03-15-2011, 12:03 AM
Thanks for the advice. I didn't even think to have the old one rebuilt. Oh well...live and learn. I will take this one off and grease it though. Something to do tomorrow...
Old 03-15-2011, 12:19 AM
Standard procedure is to lay a couple towels below the starter to cushion the fall in case it slips. Hate to have it end up on the cement under the boat the hard way.
- Peter
TIRE & WHEEL SALES
Old 03-15-2011, 06:43 AM
dmminfla's Avatar
dmminfla dmminfla is offline
Boat: 1997 PS 205 350 CI 275 HP TBI
You could have a bad spot on the ring gear. If it happens again turn thr crank a quarter and see it i works.
Old 03-15-2011, 08:55 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Yeah, missing a couple teeth on the flywheel or the bendix is sticking on the starter, put some light grease on it.
Or just possible it's a bad starter, but not likely since same symptoms as last one.
'06 X2 MCX
Old 03-15-2011, 09:59 AM
03geetee's Avatar
03geetee 03geetee is offline
Boat: 1983 Prostar 190 Stars and Stripes
Neighbor had the same problem, wasnt the starter but after replacing it and seeing the same result his battery and starter cables were the culprit. Always test your stuff before throwing new parts at it.
JTR
1983 MasterCraft Stars and Stripes
Cream/Red Metal Flake
"Powerslot"
"The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish."
-Charles Chaplin-
Old 03-15-2011, 10:17 AM
Table Rocker's Avatar
Table Rocker Table Rocker is online now
A starter should not spin until the Bendix has thrown the gear. If your starter is spinning in the air, the starter gear and ring gear are not in contact. Take your starter off and look at the teeth on the ring gear. You will probably see damage.
If a starter is not installed correctly (shimmed in most cases) and is too close to the ring gear, it will work fine for a while. But since the ring gear is usually a little out of round, the gears bind on certain places on the ring gear. After a while, the bushing between the starter gear and shaft will wear from the binding and the starter gear will become loose. The worn bushing allows poor alignment of the gears and the starter gear starts chewing up the ring gear. The next thing you know you are replacing your starter and ring gear.
Old 03-16-2011, 10:41 PM
Since I'm not "that" mechanically incline, I apologize ahead of time if my questions/replies sound dumb.
Can you do this without taking anything apart. Say I"m in the middle of the lake and this happens again...is there an easy way to turn it?
Since I do get a little impatient, I already bought and installed a new starter yesterday...thinking maybe the last one wasn't good. We'll see I guess.
JTR
Is there an easy way to test this stuff out? It's definitely a habit I need to get into when things like this happen.
You might be dead-on with this one. I definitely didn't shim the new one when I installed it. Is there a standard shim that needs to be used for these? Also...about the ring gear...and this may sound stupid...but I'm guessing it's pretty involved to change it?!? Meaning, not something I should try at home?
problems, prostar, starter
