Old 02-22-2011, 11:44 AM
mrprostar's Avatar
mrprostar mrprostar is offline
Boat: 1996 Prostar 205
Whats this wire do?
I have 96 205 with the 5.7 TBI. My temperature reading was getting very high so began doing some looking around. I replaced the thermostat in the intake manifold (160 degree), no change. I tried to find a replacement for the one in the triangle block but couldn't find one the correct size. So I left it out completely and the temperature stayed lower but when running at any rpm above idle the temperature shoots way up with 190 then plummets very quickly to 120 then gradually goes back to 190 and repeats. I replaced the thermostat in the intake manifold again thinking it was sticking and then finally opening at 190, but it didn't change. I began looking around again and found a wire on top of the thermostat housing that was broken at the connector. I havent been able to find the same connector for a replacement, but was wondering what this wire does and could it have something to do with my problem? I understand that the thermostat I removed it supposed to keep the water in the system warmer so 50 degree water doesnt enter the block, explaining why it the temp drops so fast and so low. But why isn't it opening at 160? Before it would fluctuate from 140 to 165 and never any hotter.
So to stop rambling and get to the point:
What does the wire do?
What is the part number (skidim) for the thermostat in the triangle block?
Where can I find another connector that has the screw into the thermostat housing and then a screw on wire connector on the other side?
Thanks in advance.
1996 Prostar 205
Old 02-22-2011, 11:54 AM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
You should check the trans cooler for blockage/obstructions. If plugged from debris that gets sucked out of the water will reduce the volume of coolant flow through your engine.
Oh, and pics of your wire could help the second question...
Need LT-1 parts?
89058397 (pump outlet side)
Old 02-22-2011, 12:24 PM
Barefooter92's Avatar
Same problem this past summer same boat. Check your trans cooler. This will eliminate 50% of your problem and posts from TT members. This should only take you 2 min to check and clean. Part of my rutine maintenance now.
Old 02-22-2011, 12:35 PM
Thanks in advance.
Wire color and photos- post both.
These have two temperature senders- one for the gauge and one that reports to the ECM (one yellow one and black wire). If the one with the broken wire has only one wire, that's the one for the gauge and it should go to full cold if you disconnect it. If you short it to ground, it should go to full hot.
Old 02-22-2011, 06:27 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Doesn't the 5.7 TBI have only one thermostat?
Keep skiing!!!
Old 02-22-2011, 06:52 PM
Double D's Avatar
Double D Double D is offline
This wire?? I think its to the red light on the dash. To hot = red light.
I could be wrong...
1994 MasterCraft ProStar 205
275 HP 350 Chevy Indmar
Monster Tower & PerfectPass
Old 02-22-2011, 07:36 PM
ahhudgins's Avatar
Boat: 79 S&S, 87 Prostar Powerslot, 95 Maristar 200VRS
I could be wrong...
Same set up as my 95 TBI. Mine is put away for another month, but the two sensors on top of the manifold are for the temperature gauge and the over temperature light you mentioned. One has a brown wire, the other has a brown wire with blue trace (I think). My sensor for the ECM (as JimN mentioned) is on the side of the block below the spark plugs. It has two wires: Black and yellow. My 95 only has one T-stat.
Old 02-22-2011, 08:20 PM
ahhudgins's Avatar
Someone can correct me if I’m wrong, but I still had this old picture from when I was trying to explain to a friend how the thermostat works. I don’t know if my 95 has another t-stat below this one, don’t know why it would need one?
Lake water leaves the impeller and enters the triangle housing through the large hose in the bottom left (marked with pink arrow) and goes through the housing to the other large hose for the engine water pump which pushes water into the block. Water is also directed up through the small hole to supply water to the exhaust manifolds. Water is HELD in the block until it heats up enough to open the t-stat. T-stat opens up and directs water up (noted by blue line) to the top of the housing and out the exhaust manifolds. An infrared temperature sensor can be purchased for less than $100 to check your actual engine temperature to see if it’s over heating or you have a gauge/wire problem.
My 95 uses a 142 degree t-stat that I got at NAPA. Any local auto parts store will have them.
Old 02-23-2011, 10:26 AM
mrprostar's Avatar
Double D- yes that is the wire. Thank you, I'm sure thats what it is for. I will have to double check, but I don't believe there is a sender on mine like that. I cant find a picture of the connector and the boat is at my parents house. I'll try to get a picture this weekend. But the connector is a little screw without a head on it and it screws into the housing on one end and then the connector is screwed on it with the wired crimped on the other side.
ahhudgins - Also a good picture of the wire on the right side of the picture. Definitely the tan wire. Your explanation is the same as my understanding. The second thermostat I was referring too was in the hole where the blue arrow is and the other one is in the intake manifold, like in the picture.
So what does it do? It looks like it keeps water from entering the exhaust manifolds until its hot?
1996 Prostar 205
Old 02-23-2011, 10:32 AM
ahhudgins - Also a good picture of the wire on the right side of the picture. Your explanation is the same as my understanding. The second thermostat I was referring too was in the hole where the blue arrow is and the other one is in the intake manifold, like in the picture.
It works as a T adapter- to allow cater to go to the engine and it also provides a constant supply of water to the exhaust manifolds.
