Old 02-17-2011, 01:23 PM
Huskie05's Avatar
Huskie05 Huskie05 is offline
Boat: Mastercraft, X55,LSA
Flushing Ballast Tanks
New owner, a lot of questions. We go to Lake mead a lot, Zebra Mussels are unreal, you have to flush the motor when you get home. I have the attachment for the motor, but how do I flush the tanks?
Old 02-17-2011, 02:08 PM
SteveO's Avatar
SteveO SteveO is offline
Boat: 2017 NXT 22
Assuming your boat has the side discharge for the ballast overflow, you could force water into those ports and then drain the tanks through the bottom fill ports?
2015 NXT20
2007 X2
2002 209
Old 02-17-2011, 03:03 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
Do you need to flush with anything besides water? If you already have the plunger you can hook that up to the ballast intake on the bottom of the boat too. There is usually a place between the ballast shutoff at the hull and the ballast manifold on the transom where you can inject into the ballast system. There was a winterization kit for sale over at w8ke.com designed to beable to suck in anti-freeze that should work if you needed to flush with something other than water from the hose.
2006 Maristar 200 SS
Old 02-17-2011, 03:21 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Chlorine or HOT water, like 140 F + will kill zebra mussels. Not sure what the chlorine content needs to be though. Assuming you have a manifold that the ballast water runs through, you could fill the tanks partially with a chlorine solution or very hot water. Don't know if you could turn up the water heater in your house enough though.
If you went the chlorine route and didn't want to discharge chlorinated water you can neutralize the chlorine with sodium thiosulfate. Can get that stuff at pool supply or utility pipe supply places.
If the rules are like CO with respect to zebra mussels, your boat needs to be tagged from the previous lake "mussel free" or the fish cops have to de-con your tanks. I inquired about de-conning my own tanks with chlorine as opposed to having some dufus try to inject 180 deg water at 4000psi from a big Hotsy pressure washer thru my intake with a fake a lake! (He got soaked and scalded)
They wouldn't go for it, so I just try to stay off of the mussel lakes around here and if I do go to a mussel lake, I dump a little chlorine in the tanks and then try like hell to talk the next ranger out of de-conning my tanks (tell them it's the first time the boat hit the water this year or I was only at a certain mussel free lake last).
If you need to get the boat de-conned, figure out first if you can push water into the tanks thru the overflows or rig up a hose connection to run hot water in thru the manifold (like winterizing). This will make the de-con preocess go much quicker and aleviate boat stress waitign on them to mess around getting hot water into your tanks.
'06 X2 MCX
Old 02-17-2011, 03:34 PM
TallRedRider's Avatar
TallRedRider TallRedRider is offline
Boat: Used to have 2006 X-45....
At Sand Hollow the decon process is pretty well a joke. They stopped flushing the engines due to concerns about liability. Then a few boats had intakes that were right under the bunks (talk about poor design). And they don't know how to use a perko flush kit either. They haven't been smart enough to ask me about my ballast tanks.
I hate to recommend anything that is dishonest...but I would do what Thrall says, and also consider avoiding Mead unless you know you can have the boat out of the lake for at least the recommended amount of time (which used to be 1 week in the summer, longer as the outdoor temp cools, but seems to change every so often).
Be excellent to one another.
Old 02-17-2011, 06:07 PM
Huskie05's Avatar
Thank you everyone, this is very helpful. Thank you!
Old 02-18-2011, 07:53 PM
[email protected] jason@wakemakers.com is offline
Boat: Malibu
What year and model is your boat?
Old 02-18-2011, 09:05 PM
Huskie05's Avatar
2011 X55 thanks for any help!
Old 02-19-2011, 09:33 AM
Cmpdman's Avatar
Cmpdman Cmpdman is offline
Boat: MC
We've up in Logan. At Lake Powell, they always flush the ballast tanks with HOT water (140 degrees). They insert the hose into the side of the boat (ballast overflow port). They pump in about 5-8 gallons in each tank.
Heres a link to a PDF. I think around page 16 has cleaning requirements
Old 02-21-2011, 06:25 PM
Boat: Malibu
Yep, Cmpdman's description is the easiest way to do the job on a lot model boat. If your boat is older than 2005 there are other things to consider.
