S&S Vibration
When I took mine out Sat. to me at full throttle it had some vibration. Is this caused form it having a 351 in 2200 lbs boat? It may just be me. I just want to make sure this boat is right. Around 35 it was smooth. Any input would help! Thanks!
Was the vibration you felt at full throttle in forward or in reverse? OK, seriously there are a lot of things that can cause a vibration. What is the condition of the prop? How about the engine? A slight miss can really show up under load. Engine alignment is another. How easy or hard is it to turn the prop while the boat is on the trailer? Those are probably the most likely sources.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
prop may be out of balance, shaft me out out of alignment or bent
Quote: Originally Posted by Hoosier Bob She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
The owner before me did do some trans work. He changed the seals. Is this an easy fix? Something i could do?
Prop should be kind of hard to turn without the transmission running. Of course you don't want to get anywhere near the prop with the engine running. With good engine alignment you should be able to turn the prop with one hand. Not an expert on this yet. I know the boat is new to you. What are the condition of the plugs, wires, dist cap & rotor, fuel filter. Is the timing set to specs? Is the advance working smoothly? Even old gas can cause an issue at WOT that you may not notice at part throttle speeds. And it doesn't take much of a bend on a prop blade to cause a vibration.
#7
there are threads on here about alignment. Only way to tell if the shaft is bent is to pull it. Alignment there are measurments that I can not recall
#8
I'm not sure what your used to, but my friend that had an 86 Nautique always thought my boat shook more than his and was louder. I thought the same, but of course my wake was 3x better! We checked alignment of the engine/drive shaft and it was all good. Just a bit more vibration than he was used to. No prop issue either. In my opinion, that era MC has a bit of a vibration at certain RPM ranges.
As far as prop turning hard on the trailer, that may depend more on how recently you have operated the boat and how tight the packing nut is. If the vibration is excessive, I would first check prop condition, then alignment to engine, then it is possible the shaft could be bent, but don't fret just yet. It could be all normal. |
#9
When i tried turning the prop... it was before i put it in water from it siting all winter. |
