Old 07-11-2005, 10:42 PM
footin123 footin123 is offline
Boat: 1994 Maristar 200
Rub rail leaks??
I have a 1994 maristar 200. The rub rail was removed and replaced (caulked all screws when replacing them) and I have removed the back seat and tank and sealed the entire inside, but still getting lots of water at 10-20 mph. Has anyone had a simiar problem and remedy?
Thanks
Tom
Old 07-11-2005, 11:01 PM
stars93 stars93 is offline
Boat: 1993 Prostar Stars and Stripes
During my first few weeks with my '93 I noticed water POURING in the back right of the boat anytime I made a slow left turn. It was hard not to notice because the rear corner became saturated with water during these turns. All I did was seal the bottom lip of the rubrail where it met the fiberglass. I used some clear marine grade silicone and water never poured in again.
Old 07-12-2005, 09:48 AM
Hey footin
My boat leaked like that - I used polysulphide black caulk (BoatLife) anf just ran a bead up under the rail - if you use masking tape, you'll get a nice straight bead that won't need much tooling (with your finger)...my boat's rail is black with a black stripe just under it so the "repair" just disappears...
Due to the config. of the hull back there, get someone to drive at 20 mph +/- and if you stand back there and look you'll see water being kicked right up under the rail and consequently, forced thru the crack...
Wes
Old 07-12-2005, 06:24 PM
John 3:16-18
Old 07-13-2005, 04:36 PM
Thumbs up Thanks
Thanks everyone for the advice. I'll give it a shot and let you know!!
Footin
Old 07-14-2005, 06:10 AM
Boat: 95 PS 190 EFI
Hey Wes - did you ever get your motor straightened out?
If one day you're asked:
Will you say:
It's time to SKI.
Old 07-14-2005, 03:19 PM
Hey jimmer,
The boat's at the mechanic as we speak...one cracked head - $1,100 +/- ouch! as they say - break out another thousand....hopefully thebottom end tests OK.
Wes
Old 07-22-2005, 03:16 PM
BobJ
Same leak in 2003 MS230
Just tried the silicon fix under the right rear end. My neighbor with a MS 210 1999 had the same leak. Has the factory offered any guidance? Seems like this is a very common problem.
Old 07-15-2010, 11:36 AM
kdskier
I am getting more and more water in the center bilge compartment?
1999 Maristar 210.
Heater system is by-passed. (We never use it.)
Motor bilge is dry.
I don't get it?
Prop seal?
Old 07-15-2010, 11:56 AM
flipper's Avatar
flipper flipper is offline
Check your packing on the drive shaft
'91 prostar 190
