Trouble Launching Boat
I do not have a MC trailer but it is a drive on trailer for an IB type boat.
The boat trailers great. But when I unhook the winch strap from the bow eye when unloading the boat, the bow drops down and rubs over the winch stand roller bow stop. At one point it rubbed so hard that it pulled the rub rail off at the bow. I have tried floating the boat off with the trailer deeper in the water but this does not help. Do I need to have the trailer modified to take care of this problem? Any suggestions would be greatly appreciated. Last edited by skilew; 07-11-2005 at 08:52 AM. |
Without seeing your rig, it's tough to tell but it sounds like you are in too deep with your trailer when you launch.
1997 Prostar 190, TBI 350, 1:1, OJ XMP 13 x 11.5, Stargazer, Hot Shower, Heated Drivers Seat, Reuben/Mountain Rock/Nite Navy |
I have tried it at various depths but still no success. I am wondering if I may need another keel roller closer toward the front of the boat.
Sounds like you will need to modify it.
I have the same problem with my boat / trailer when I launch.
When you back in, put the trailer in the water just enough to get the water intake in the water. Then drive the boat off. If you have the trailer in shallow, the boat will still be on the bunks till it is about haft way off the trailer.Just make sure it is in deep enough to get water to the engine when you start it. If this doesn't work you might have to raise the bunks on the front of your trailer. |
#7
Sounds like I need to try and launch at a shallower depth. I will try this weekend and hope for better results.
#8
I don't know how old your boat is but when I bought my '79 a year or two ago I put the back end in and tried to drive it off the trailer. I put it into reverse and the boat twisted weird and the front rudder fin hit the steel trailer support! Completely bent the rudder. And the worst part was the place that I asked to fix the thing couldn't bend it back perfectly straight. Umm, so I never back it off I always dump it very deep and push it off now. But I don't know if that helps you because the '79's didn't have winches. Just my
'79 all the time |
#10
Launch at a shallower depth. The rule of thumb I use, the water should barely be at the top of the fenders of the trailer. We have been successful with this rule at numerous launches at many levels.
Thread Tools | |
Display Modes | |
