Need advise LQ9 winterize
I'm new to the Mastercraft X30 2003 LQ9. I want some advise on winterizing this closed system. It can't be very difficult. Can this forum give me some insite on the process. The engine is an LQ9, I just need some assistance.
Super easy, this is what i do....
Remove airfilter from the front of the engine. Start while still in the water and spray fogging oil in while revving the motor a bit. Replace airfilter. Remove two drain bolts from the heat exchanger, undo the hose coupler that links the two exhaust manifolds, remove hose from the exit side of the raw water pump and turn the motor over a few times without saftey lanyard attached to get the water out...done. If you have a heater you leave it because it is full of antifreeze not water. Remove bottom drain and put in ziplock bag along with the heat exchanger bolts. Ziptie all to steering wheel. Write a list of what you did on the ziplock bag and the date. Somepeople change the oil and tranny fluid but I do that in the spring Ballasts?..you are on your own as I am a ski guy (197). Done....
04 197 TT LQ9 stargazer w/Z-Box PB 1@35off Previous... 96 Prostar 205 Lt1 93 Prostar 205 HO 81 Leaves and stripes(Can. edition) Last edited by rhsprostar; 10-05-2010 at 07:38 PM. |
Oh I also check the strength of the antifreeze with a special tester for proplyen glycol.
Bought it at an autoparts store for about $20. Not the same as a regular antifreeze tester! It has always been perfect but you have to check for peace of mind... ![]() The test takes about 30 seconds.
04 197 TT LQ9 stargazer w/Z-Box PB 1@35off Previous... 96 Prostar 205 Lt1 93 Prostar 205 HO 81 Leaves and stripes(Can. edition) |
change the oil and tranny fluid before it sits for the winter. I keep a light bulb on in the engine bay to minimize moisture.
I have never fogged my MCX, fogged my 2 stroke waverunner. I am not in a super cold climate, do you frigid-tundra guys fog??
Thanks so much...Seems easy enough and saves a load of cash. I appreciate your taking the time to respond.
All the best to you! |
#7
Obviously there are many ways to winterize an LQ9. Many of them are sure to be just fine. A few things I do different...
I would recommend changing the Engine and Tranny oil before you store it. Deposits in the oil are not good to leave sitting in the bottom of the oil pan for extended periods of time. Plus, in the spring who wants to take the time to change oil when you want to get it out on the water! I only remove 1 plug from the heat exchanger, the one you want to remove is the port side drain (fartherst from drivers seat). The Starboard side drain will drain your antifreeze and you don't want to do that. Remove your impeller, coat it with vaseline and stick it in a plastic bag. Leaving it sit in the housing dry all winter is a good way to prematurely wear it and cause it to fail. Disconnect the hose that runs behind your engine on top of your Trans. It is a regular garden hose fitting. I also fill the tank full of Non-Oxygenated fuel and add Stabilizer. Remove battery and charge it, store it inside.
2002 ProStar197 Tournament Team Edition (yes it's Red) *LQ9, Powerslot,Perfect Pass,Zero Flex tower,Heater |
#8
Stabilizer is a must as well. Put it in before your last run. You want to make sure you get it into the engine and not just in the tank.
