Old 09-30-2010, 06:41 AM
amcmac amcmac is offline
Boat: X2
OH CHIT! There is water in the boat.
These were the first words my wife yelled at me when she dropped me last night. Guess who forgot to put the plug in. Water got up to about the floor level on my X7. About half of the starter was in the water. It was getting dark so I couldn't see the tranny very well. How screwed am I? Should I be doing anything. Any help is much appreciated. Also, do you guys have any routines or processes that help you not to forget the plug?
Old 09-30-2010, 07:02 AM
tex's Avatar
tex tex is offline
Boat: 2002 Prostar 197 w/tower
Lay it in the driver's seat!
2002 Blue Prostar 197, 0 Flex Tower, Perfect Pass, and The Preditor-ADHD Skier
I'm pursuing my lifelong quest for the perfect, the absolutely driest martini to be found in this or any other world. And I think I may have hit upon the perfect formula :
Old 09-30-2010, 07:06 AM
OldGlory's Avatar
OldGlory OldGlory is offline
Boat: 1982 Stars & Stripe (Blue on Blue), 351w, PowerSlot
tex said it best (IMO)...driver's seat! That way it will end up where it should be, or where it shouldn't be
Old 09-30-2010, 07:13 AM
Boat: Boat
I put a small lanyard on mine and I lace it around the steering wheel.
If the water was that high I wouldn't even question it, I would drain and refill the transmission twice. I'd run it for say an hour and check it for foam.
Gone, surfing.
Old 09-30-2010, 07:58 AM
dmminfla's Avatar
dmminfla dmminfla is offline
Boat: 1997 PS 205 350 CI 275 HP TBI
I put mine in the cup holder on the dash.
Old 09-30-2010, 08:15 AM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
I put mine in the threaded hole on the bottom of the boat so no water gets in
Old 09-30-2010, 08:44 AM
06197ttlq9-footer's Avatar
06197ttlq9-footer 06197ttlq9-footer is offline
Boat: 2006,197 Tournement Team LQ9
Location: Maryville TN. 20min from the center of our Universe.
Usually I am the one that puts the boat on the trailer and as I am being pulled out of the water then I remove the plug. It remains out until I arrive home and after the bilge is wiped with a towel the plug goes back in. When arriving at the lake as the boat is being backed into the water I double check it visually. 20+ years and I have put the boat in once without the plug because I laid it in the floor in front of the drivers seat. And the one time I did it the boat didn't get off the trailer because of my visual double check. It's a drain plug use it to drain the remaining water from the hull and put it back.....no problem.
Old 09-30-2010, 09:06 AM
MattsCraft's Avatar
I only forgot it once; however I was still on the trailer. (V-Drive) Part of my launch routine is after the boat is in the water, still hooked up, I start the boat, lift the rear hatches and check to make sure the engine is getting water via the Perko flush kit (love that thing) and the rear bilge and hoses for any water. The one time I forgot the plug, water was gushing into the bilge, quickly had the driver pull up, put in the plug and all is good.
Using this routine will guarantee everything is working properly etc. before you leave the dock! This only takes a few seconds and I think the safest and best insurance policy you can have!
Old 09-30-2010, 09:11 AM
loeweb's Avatar
loeweb loeweb is offline
Boat: 1988 Prostar 190, 351W Indmar, 4160 holley carb, 4 blade acme force prop, 1:1
Put mine in the glovebox. I guess I have been lucky so far in that I remember to lift the motorbox before every outting, and put the plug in at that time.
go go go!
Old 09-30-2010, 09:20 AM
vision's Avatar
vision vision is offline
Boat: 2008 X Star, 2005 X2
LOL
I agree. Seems to be a safe location.
2008 X star, 2005 X2
