Old 09-08-2010, 08:42 AM
dlboltond dlboltond is offline
Boat: 1992 Mastercraft Maristar 210
Gas smell at idle
I have a 1992 Maristar with a 351 Indmar and a 4160 (i think) 80319 Holley 4 bl.
I am getting a strong gas smell at idle - people in back are getting loopy. It seems as though it is idleing pretty slow ~200. Could low idle be the problem, or is it just running to rich? Otherwise it runs great. What is the target idle RPM for this engine?
I put in new plugs but that didnt help. If it is the idle adjustment, could you give me some pointers on how to correct?
Old 09-08-2010, 10:13 AM
oldairboater's Avatar
oldairboater oldairboater is offline
Boat: Mastercraft, Prostar, 1992, 351 Ford
Is this a new problem or was it like this when you bought it? Your idle speed is too low if your tach is right. There is an idle speed adjustment screw on the passenger side of the carb where the throttle cable ties into the throttle body. There are a few mixture screws on your carburetor also. Your carburetor may need more then just idle speed adjustment. Do a search on how to tune a holley. There are better people who know how to tune a holley. I just do trial and error.
Old 09-08-2010, 10:31 AM
I am the second owner and it has always been like this. I believe the idle is low because it is lopes and when in gear, the boat seems to shake a little. I really dont know how to describe it. When I tap the throttle and the tach reads around 600 it is much smoother. Do you know what the idle should be?
I have the .pdf on tuning the carburateor and it says that there is a primary adjustment (the one you describe) a secondary screw. It says that "the adjusments should be made to both the primary and secondary screws in equal amounts". What does that mean?
Old 09-08-2010, 10:49 AM
russfortin's Avatar
russfortin russfortin is offline
Boat: 1987 mastercraft prostar 190 ford 351 / 2002 Prostar 197TT
Just means that on both sides of the carb, there are mixture screws. if you change one, change the other the same amount. Good rule of thumb is turb them all the way in (right) then slowly turn them left until it runs a little rough. then turn back to the right a full turn. Should end up being about 3 full turns from all the way in.
Hope that helps
Old 09-08-2010, 11:44 AM
If you are really idling that slow you would smell some raw fuel. Your idle speed should be in the neighborhood of 600 - 800 RPM at idle in gear. Need to set it in the water. On the trailer won't work.
Old 09-08-2010, 01:06 PM
It specifically says - secondary throttle stop screw. I also found the part around mixture screws.
Thanks
Old 09-08-2010, 01:08 PM
Thanks thatsmrmastercraft. That is what I was looking for. So just put it in gear and turn the idle screw on the side? Can you comment on the secondary screw?
Old 09-08-2010, 01:59 PM
Idle speed adjustment is done by turning the idle stop screw (to use Holley's terms). The secondary throttle stop screw's function is to keep the secondary throttle plate from becoming closed to the point where it would be jammed closed.
Old 09-08-2010, 02:21 PM
flipper's Avatar
flipper flipper is offline
One a side note, make sure to run your blower good and long. Don't want to blow you boat sky high before you get it running right.
'91 prostar 190
Old 09-08-2010, 03:27 PM
Will do. Always run the blower. I will let you know how it works. May be a couple of days.
gas, idle, smell
