Fuel Pump Issue???
Hey - I'm having problems with my 96 Prostar EFI. The boat idles fine, but it seems to hesitate when throttled down. Has the feeling like it is running out of gas - Which leads me to believe it is the fuel pump.
Any thoughts from anyone? Any recommendations on where to pick up a fuel pump (and what type) at a decent price? Thx guys ch |
do a search - you'll find tons of threads here on that.
My guess, is the screen on your pump is clogged. Happened many times to my '95 PS190. The pump is on the passengers side, rear of the motor. You'll need to pull the pump off. then, take off the fitting at the inlet. Inside there, is a screen. My money is that it's full of debris.
If one day you're asked: " How did you spend your time here on Earth?" Will you say: "I kept a crabgrass free lawn" It's time to SKI.
I'll say it again- DO NOT REPLACE PARTS WITHOUT TESTING THEIR FUNCTION FIRST!!!!!! Unless you know the fuel pressure isn't correct, replacing the fuel pump will only waste money. If you have no problems with acceleration, it's not the pump. By any chance, when you wrote 'throttle down', does this mean that you're trying to accelerate? That's not throttle down. Just trying to make sure we mean the same thing. If this is happening on acceleration, it could be the pump but I would recommend checking the screen and if the filter is more than a couple of years old, change it. The tank has a fuel pickup tube, too and this may be clogged. Last edited by JimN; 08-20-2010 at 09:32 AM. |
