Old 06-29-2011, 05:48 PM
Justjoe's Avatar
Justjoe Justjoe is offline
Boat: 2006 197 and 2007 X2
No power, no nuthin.
Went to start the boat. Turned the key and heard the standard click click click, turned all the way to start.
Sounded like a dead battery kinda, but maybe more like a little sizzle click sizzle click. I turned the key back to off to retry, and I've got zero.
No fuel pump sound, no perfect pass or instrument gauges...anything on the circuit that has to have the key on, I've got nothing.
The blower works, the ballast pumps work, lights work.
I messed with the kill switch (which I never use or touch) and got no change.
I checked all the breakers under the dash. Nothing.
The breaker next to the battery does not seem to have popped either.
Help. The dealer says "i'don kno....."
Old 06-29-2011, 06:01 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Start by checking/cleaning all the heavy cables from the battery to the starter and back to the battery. All connections should be clean and tight, including both ends of the ground cable.
http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
89058397 (pump outlet side)
Old 06-29-2011, 06:07 PM
Justjoe's Avatar
Pulled all the battery cables, flipped the batteries, put em on a charger (good charge).
Old 06-29-2011, 06:27 PM
Justjoe's Avatar
Bypassed the 40 amp breaker by the batteries, nope.
Old 06-30-2011, 01:27 AM
JLeuck64's Avatar
That breaker has nothing to do with the starter. Might be a good idea to remove the starter motor and have it tested at this point.
Need LT-1 parts?
Old 06-30-2011, 02:10 PM
rholmes's Avatar
rholmes rholmes is offline
Boat: Mastercraft, Maristar 210, 351, bought in '07 with 227 original hours.
Check the starter solenoid?
If it's a penny for your thoughts & you give me your two cents, what happens to the other penny? Taxes, the democrats tax everything!!
1990 Maristar 210... Sold
In the market though...
Old 06-30-2011, 02:14 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
How does your ignition wiring look under the dash. I had a wire come lose from the back of the ignition/key and it was a pretty frustrating couple of hours before I figured it out.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 06-30-2011, 03:00 PM
vision's Avatar
vision vision is offline
Boat: 2008 X Star, 2005 X2
I am sure it is not the cause since you initially had a response. But make sure the gear shifter is in neutral. I can never remember if the gauges stay dead with the neutral lock out switch?
2008 X star, 2005 X2
Old 06-30-2011, 03:28 PM
Justjoe's Avatar
Ok. Tightened the wires going into the starter and *whalaa*. Situation resolved.
And seriously, tightened. They were there and attached. Couple threads on the post.
