ATB's
Before..........
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
After!!!!!!!
Around the boat's here I come! Thank you BAW's, you guys helped us get this act back into the show for this coming weekend! Now we just gotta re-learn how to do ATB's, been doing them backwards behind a Nautique for years now...
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) Last edited by JLeuck64; 06-15-2010 at 05:14 PM. |
Backwards....You should be able to do them either way in both boats.
2002 Blue Prostar 197, 0 Flex Tower, Perfect Pass, and The Preditor-ADHD Skier I'm pursuing my lifelong quest for the perfect, the absolutely driest martini to be found in this or any other world. And I think I may have hit upon the perfect formula :
Can you do ATB's on a boat with a tower? Say a 2006 X2??
2006 X-2, MCX, Blue and White |
not off of the ski-pylon.......
KEEP YA TOES UP!!!!! 2004 X9 MCX ALL BLACK http://www.prwb.net/tallington/index.php?id=12 nice older x-boat at berth in the advertisment above |
Just a little update...
If you plan on doing this modification be aware you are using your boat in ways that were never intended. I noticed the lower pylon mount failing after probably a dozen or so ATB's with 3-4 skiers in tow. I would strongly suggest you modify your lower pylon mount with something stronger than the OEM version, it can't handle the side loads generated. I fabricated a close replica out of some steel, instead of aluminum.
