Old 06-21-2010, 03:50 PM
SDProstar's Avatar
SDProstar SDProstar is offline
Boat: 1991 Prostar 190
Used Exhaust Manifolds
I originally bought my 91 Prostar as a "fixer" without a motor but I now own a rebuilt 351w long block. Among the many parts I need are exhaust manifolds.
I found these on Craigslist http://sandiego.craigslist.org/csd/boa/1802085286.html and talked to the seller. He claims that they look very nice and the engine they came from had low hours. However, he is certain that they came from a Ford 302.
From looking at the BARR catalog/website they seem to list 351w and 302 manifolds as the same part number. Does anyone know if the two motors use the same exhaust manifolds?
Thank you,
Chris
1991 Prostar 190 (undergoing restoration)
Old 06-21-2010, 04:02 PM
dmminfla's Avatar
dmminfla dmminfla is offline
Boat: 1997 PS 205 350 CI 275 HP TBI
The 351 and 302 are the same block. So they will fit. Check the diameter of the riser where you attach the exhaust hoses. The pic looks like they are smaller than normal
http://bpi.ebasicpower.com/exhaust/pcmex.php
Old 06-21-2010, 04:15 PM
You got the correct advice on the 302 & 351 exhaust being the same.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 06-21-2010, 05:50 PM
Mr_Woodcock's Avatar
Mr_Woodcock Mr_Woodcock is offline
Boat: Mastercraft, Pro Star 190, 1990, Ford 351
If you get these I would recommend dipping these things in Muriatic Acid for about 4 hours to clean them out. You can do a 50/50 blend with water. Make sure you look into the exhaust ports to see any major rust in them. After dipping repaint. You can definately tell if water had been leaking into them through a cracked wall or bad riser gasket. I would definately bargain with the price a bit.
Old 06-22-2010, 09:56 AM
SDProstar's Avatar
Thank you, everyone, for the information and advice.
Although our boat came to us with no engine, the exhaust hoses were there so I’ll take one along to make sure they fit.
I’m thinking of offering the seller $150, and perhaps settling around $175.
If I get them I’ll post back with pictures, etc.
Chris
Old 06-22-2010, 09:59 AM
Should be 3" unless its a 351HO which I believe is 3 1/2".
- Peter
TIRE & WHEEL SALES
Old 06-22-2010, 12:11 PM
Make sure that you take a flash light to look inside the passages. Idealy some gently used ones should not be clogged up. Look at the rusted areas and see how much corrosion has taken place.
Old 06-22-2010, 01:13 PM
Napagary Napagary is offline
Boat: 1976 Mastercraft
Can you separate the riser from the manifold for a look-see before making the deal?
Old 06-24-2010, 12:43 PM
SDProstar's Avatar
They are mine, now...
OK, I bought them!
I paid $100 each, but the seller agreed to deliver them to me (a 60 mile round trip.) They really are in nice condition with minimal rust.
They match my exhaust hoses, coming off the muffler: 3"
I did. There is some rust, but they are not clogged. We connected a hose to the hose fitting and water freely flowed through the discharge. There's no sign of rust in the exhust ports, and they are pretty clean. The boat they came from was older (not sure of the year) but only had 153 hours.
I did not do this before I bought them and probably should have. The gaskets show no sign of ever leaking.
Now I have to decide:
1. Clean them up and paint with black hi-temp paint to match my rebuilt engine?
2. Separate the risers/manifolds and bead blast before painting?
3. Get all fancy and have them ceramic powder coated (I have a friend in the business.)
Old 06-24-2010, 01:30 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Cermic coated for sure if you got a connection.
If they weren't leaking I'd leave them together.
'06 X2 MCX
