Some rudder DIY
Replaced my steering cable and I’m still not 100% satisfied with the stiffness in my steering. I’ve seen a few posts about cleaning out the rudder box so I brought the boat home to take care of a few small things. Thought a few pictures may help someone else in the future. Took these pictures when I was putting it back together, noticed there was a hole in the rudder shaft but no pin. Should there be any kind of washer on top of the rudder? I had a nylon washer between the arm and box and I went ahead and installed a cotter pin in the shaft. I disconnected the cable from the arm to make it easier to handle. I was working by myself so I put a floor jack under the rudder since I didn’t now how easy it would come out.
Once you take the nut off of the thru bolt, you have to remove the bolt because it is threaded into the arm. It's not like a battery terminal clamp that comes off when you loosen the nut. If you remove the bolt completely, it makes it easier to put a screwdriver in the slot and lightly tap it. My arm slid right off and then I lowered the rudder with jack.
There was nothing in the rudder box other than a few drops of water
. I cleaned it out from top to bottom, removed and cleaned the grease fitting, then pre-greased everything a little bit before putting it back together. Once it was back together I hit it with the grease gun until it came out from the bottom O-ring. I'll give it a test this weekend. |
