Old 06-23-2010, 07:43 PM
Norcal420
Posts: n/a
impeller
what is the best tool to use to pull and replace the impeller thanks
Old 06-23-2010, 07:48 PM
flipper's Avatar
flipper flipper is offline
Boat: 1991 Prostar 190, fuel injected 302
search around, there are a million ways to do it. Soapy water, wd40, paint can opener, they make a puller for it.....
Lots of power is good, more is better, too much is just right.
'91 prostar 190
Old 06-24-2010, 07:25 AM
cf_koch's Avatar
cf_koch cf_koch is offline
Boat: Mastercraft Maristar 215
When I change mine I put dishwashing liquid (many people use WD-40) on the old impeller, pull the safety lanyard then bump the starter a couple of times and use two paint can openers to start to remove the impeller. Once I get the impeller out enough to grab it with plyers or vice grips I pull it out the rest of the way.
Old 06-24-2010, 09:11 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Screwdriver, needle nose vise grips, paint can openers. Changed one when I was a kid with just a pocket knife.
If it's stuck, bump motor over between prying or un bolt the pump and rotate the pump back and forth. Grease the new one on the splines.
'06 X2 MCX
Old 06-24-2010, 09:17 AM
Granite_33's Avatar
Granite_33 Granite_33 is offline
Boat: X-9
Since I have a direct drive its easy for me to grab the impeller with 2 needle nose pliers, one on each side and work it out that way.
I try to keep from prying since previously it put a bunch of nicks in the impeller housing.
Is this a DD or V?
04' X-9.
91' Maristar 210.
The bad thing about boats, is when they break, they break expensive.
Old 06-24-2010, 10:39 AM
oldairboater's Avatar
oldairboater oldairboater is offline
Boat: Mastercraft, Prostar, 1992, 351 Ford
I actually grabbed mine by the vane with a needle nose and slid it out. I used a good antisieze lube on the shaft before reinstalling. Will see how that works out next year since this will be at least an annual change out. To many smart people on here saying change it annually and it makes sense--so I will. Impeller is cheaper then an engine any day.
Old 06-24-2010, 10:42 AM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Lubricant and profanity.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 06-24-2010, 01:57 PM
Jorski Jorski is offline
Boat: 1993 190 with LT1
The amount of profanity is inversely proportianal to the amount of lubricant !
Old 06-24-2010, 02:32 PM
CruisinGA's Avatar
CruisinGA CruisinGA is online now
Boat: '01 X9 330HP
I use the same flat head screw driver that takes off the cover screws to remove the impellar.
It's been said before, but soap works great as a lube for installing the new one.
Bailey
'02 X-9
Lake Blue Ridge
Old 06-24-2010, 04:52 PM
stuartmcnair's Avatar
stuartmcnair stuartmcnair is offline
Boat: 1989 Prostar 190 351 Indmar
Send a message via MSN to stuartmcnair
I pull a lot of wire through conduit so I use the Ideal conduit lubricant to pull them and put them in...works great and will not harm anything
You can get a bottle of it on the electrical aisle at Home Depot. Also works well for getting feet into bindings.
This board be a changin...
