Old 06-21-2010, 12:53 PM
Debo
Guest
Posts: n/a
Question Problem cranking Prostar when hot !!!
I have a 97 Prostar that runs great and cranks up fine when cold but once it gets hot it takes forever to get started, sometimes wont crank until cold. Anyone have any suggestions or fixes to the problem
Old 06-21-2010, 01:34 PM
oxberger's Avatar
oxberger oxberger is offline
Boat: Mastercraft, Stars&Stripes, 351w, grey and blue
Debo, welcome to the forum. It could be several issues. The first things that come to mind are vapor lock or it may be a small crack in a vacuum line that reseals itself once cooled down. Is your engine carb of fuel injected? mrmastercraft has had some good insight to issues like this, so hopefully he'll come along and help out. By the way which engine do you have?
"The doctor said I swallow a lot of aggression... along with a lot of pizzas!"
Old 06-21-2010, 05:42 PM
rwassman rwassman is offline
Boat: Mastercraft Prostar 190, Chevy
Classic starter problems. Try an new starter and see if that helps.
Old 06-22-2010, 11:31 AM
oxberger's Avatar
Didn't even think of this, but that's a good place to look at too. Before replacing the starter though check your battery cables going to and from it to make sure they're not cracked or corroded and that they're making a good connection. That may be an issue too.
Old 06-24-2010, 11:15 PM
Debo
Guest
Posts: n/a
Prostar starting probs
Oxberger and others thanks for the replies, im not much of a mechanic but im about 4 hrs away from a reputible dealer. Anyway its a 350 efi 5.7ltr
Old 06-25-2010, 01:57 AM
It sounds like you are dealing with some high resistance made worse by heat.
I would first clean the connections at the battery, ground at the block, solenoid and starter. Remove them and clean with a wire brush. If that doesn't take care of the problem I would remove the starter and take it to a reputable auto parts store, or better yet a starter rebuilder.
Likely this will lead you to the source of your problem.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 06-25-2010, 08:33 AM
Debo
Guest
Posts: n/a
Thanks Mr Mastercraft. The engine will turn over but it just wont fire. You think that could still be connection or starter problems ? Sorry for my mechanical ignorance.
Old 06-25-2010, 09:10 AM
duffcam duffcam is offline
Boat: mastercraft 205 pro star 1995 350tbi
quote "The engine will turn over but it just wont fire"
it's not the starter then. do you operate your bilge blower at low/idle speeds (as is reccommended by MC)? you might even try leaving the engine cover open while you are sitting still, see if it's a cooling issue or a heat soaked fuel or ignition issue. my son had the same issue, we also increased the size of the rear vent on the engine cover
Old 06-25-2010, 09:21 AM
All MC motors since '94 have been injected.
Old 06-25-2010, 09:27 AM
FYI- 'crank' means "cause rotation" and 'start', or 'fire' is the correct word for the problem in this thread. This motor cranks.
High air temperature? Was it run hard immediately prior to shutting it off? If it's the first, open the motor box a few minutes before cranking it next time. You can also turn the bilge blower on for a few minutes, as recommended. If it's the latter, idle a little longer before shutting it off- not only will the motor's temperature be higher but fuel may drip from the injectors because of the increased line pressure that remains after the motor shuts off.
What else can you tell us about how it is run, maintained and any recent repairs?
