Old 06-16-2010, 01:27 PM
mramerman
Swim deck rattle
My swim deck rattles on my PS190. I am guessing the result of the brackets being bent from the stern being exposed to weather last Summer. There is a fair amount of play that wasn't there originally.
This is obviously annoying when sitting adrift. Causes some real 'banging' when the boat bobs in passing wake.
Does anyone have suggestions for a remedy?
Thanks in advance,
Old 06-16-2010, 01:33 PM
Napagary Napagary is offline
Boat: 1976 Mastercraft
Just curious how the summer weather bent the brackets? Try alloymarine.com for replacement brackets if they're made of alum.
Old 06-16-2010, 01:48 PM
mramerman
I had an unfortunate Summer moorage on Lake Sammamish in Washington. It was not very protected and too shallow to tie up with the bow exposed to the lake. The stern took a Southerly summer storm pretty hard. Lots of wave action directly on the swim deck.
Old 06-16-2010, 02:01 PM
Sorry to hear that. I'm assuming the brackets are of Alum? They may be difficult to straighten and make correct. Difficult to tell until you remove them - if they are straightened, then comes the problem of getting the platform mounting screw holes lined up again.
The link I sent on Alloy Marine might be your best shot - they're not too far away - Redding, CA. The down side there might be you'd also need to replace the transom mounting brackets - now it's getting to be a big job.
Do they still have boat races on Lake Sammamish?
Old 06-16-2010, 02:05 PM
Granite_33's Avatar
Granite_33 Granite_33 is offline
Boat: X-10
In order to find the remedy you are going to have to do some sleuth work.
Trailer it and start moving the platform around by hand, zero in on what has been broken loose. Other than that, its all guesswork.
16' X-10
04' X-9.
91' Maristar 210.
Old 06-16-2010, 02:06 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Temp solution, but just wedge some door shims between the back of the deck bracket and the transom mount. Otherwise replace the parts if they're real worn.
'06 X2 MCX
Old 06-16-2010, 02:31 PM
06197ttlq9-footer's Avatar
06197ttlq9-footer 06197ttlq9-footer is offline
Boat: 2006,197 Tournement Team LQ9
Location: Maryville TN. 20min from the center of our Universe.
Pin'em again....I mean find a stainless Bolt/Pin re-drill the aluminum Deck and Mount to snug it up. Use a drill and pin with very little tolerance.
Old 06-16-2010, 03:32 PM
mramerman
Yes, the hydros still race on Lake Sammamish. Good times!
rattle, suggestions, swim deck
